dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6656 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
לפי הפיסקה הראשונה של ידידנו ההונגרי חבל לשפץ,
אני פירקתי את הווסת לגורמים (ממש לא מסובך), החלפתי גומיות אבל ללא הועיל - בסוף קניתי ווסת חדש אצל ג'אן והמצב השתפר.
בכל זאת שווה להתנסות קצת (שוב אנגלית... הפעם מידידנו מדנמרק):
Many owners have experienced the reputed rear sink on Hydraulic models
The problem is the brake valve leaking in it's rear brakes circuit - and commonly also in the front brakes circuit after hi mileage
The problem can be overcome by overhauling the brake valve
It's strongly recommanded to do a hydracleanse cure of the hydraulic system before overhauling the brake valve
Simply to prevent your new/overhauled unit are gunked with dirt released by the Hydracleanse
This original Citroen document describes how to do it
http://www.rwbsmith.plus.com/citroen2/Brakes/doseur.pdf
It's important to clean all bits well - especially the fine bores in the valve body and pistons
The most "interesting" bits concerned - are the seals for the rear brakes circuit piston cup
These are designated & shown as items 17 & 18 in the brake valve schematic as 2 O-ring seals. One would be a flat square profile tephlon O-ring and the other would be a round profile rubber O- ring
These seals can be found in the the BX partslist page 67 as items 9 & 10
Tephlon O-ring seal : item 9 : 95 495 759 / 01 (ea.) / CNTRL-UNIT SEAL 14.7X14.9-2
Rubber O-ring seal : item 10 : 79 03 065 984 / 01 (ea.) / BRAKE O-RING 16.4X19-1.3
Some owners would have experienced the end rubber knob had split and wetted the carpets with LHM. It's then recommanded to replace this part while you have hands on the valve
Rubber end knob : item 3 : 95 640 067 / 01 (ea.) / BRAKE PROTECTOR
All other seals are provided to prevent external leakage - rarely a problem
Rarely you'll find any significant trace of mechanical wear. This is normal for Citroen hydraulic parts. They fail because of dirt - and worn O-rings included in the pressurised circuits if fitte
When the brake valve is refitted - the pedal clearance must be checked/adjusted
The BX/CX brake pedal have an end stop adjuster screw - that decides how far UP the pedal will rest
This is located behind the stop lamps switch - quite in-accessable down/under the dash in the footwell
Approx midpoint down the pedal arm - you have a circular member pushing on the protruding rubber bulb from the doseur valve
The pedal adjuster screw is adjusted for a clearance from this member to the valve rubber bulb of 0.1-1mm - using feeler blades. Try get it at approx 0.5mm
NOTES
RHD vehicles may have a spacer fitted on the valve body - and then also a spacer rod for the valve rubber bulb. Clean and lubricate this spacer rod and bore in the spacer
גם אני נתקלתי בחומר הנ"ל בשיטוטים באינטרנט, נראה קצת מפחיד הפירוק של העסק הזה.
שאתה כותב שהמצב השתפר אתה מתכוון שישנם תופעות מידי פעם?
וכמה עולה החלק הזה אצל ז'אן?
"הסטטיסטיקה הרשמית חושפת כי נהגי מכוניות ותנאי כביש בעייתיים, הם הגורמים לחלק משמעותי מתאונות הדרכים הקטלניות ב-2010 בהן היו מעורבים רוכבי דו-גלגלי". ynet
ידעתי שההסברים האלה נמצאים איפשהו ברשת, לא מצאתי אותם אצלי..
בכל מקרה זה בכלל לא מסובך ושווה לנסות, בסה"כ החלפת גומיות (הסט עולה כ 70 ש"ח בחברה) וניקוי יסודי של השסתום.
אם זה לא יעזור אז שווה לחפש אחד מפירוקייה.
בקשר לקושי העבודה, אתה מכיר את הפרסומת "..זה רק נראה יקר"? - אז שפה החלק באמת יקר, או לפחות היה כך כשאני חיפשתי כזה, באיזור ה 1400 ש"ח. ובאירופה לא הרבה יותר זול.
בריאות לכולם!
תודה רבה לכולם על התגובות, נראה איך ממשיכים מפה.
ב- 07/07/2006
הווסת בלימה עלה לי 920 ש"ח...
אגב יש מישהו בצפון שמשפץ חלקי הידראוליקה לסיטרואן,
אני יכול להעביר בפרטי אם מעניין (זו בקשה שלו לא להתפרסם...)
אני לא "נופל" מהעבודה שלו - אבל המחיר בטוח יותר שפוי,
אלעד.
  • חודש מאוחר יותר...
סתם בשביל העדכון
צינור נוזל הידראולי חוזר בבולם הקידמי היה קרוע וגרם לחוסר בנוזל הידראולי, לאחר החלפתו והשלמת החוסר פסקה בעיית הצניחה מאחורה, המוזר הוא שהמנורת ההתראה לא נדלקה למרות שהיא דולקת כשמתניעים/ כאשר הרכב נמוך.
סתם בשביל העדכון
בדוק חיבורים על המצוף שבמיכל העודפים.
אם תקין - החלף הסנסור
HFturbo
קשה לי להאמין שצינור חוזר קרוע יגרום לבעיה של שקיעה אלא אם היה חסר לך נוזל הידראולי כתוצאה מהנזילה ואת זה היית צריך לזהות מיד בדמות כתם על הכביש/מדרכה/חניה.
ידוע שכשהוסתים למיניהם מתחילים לנזול כתוצאה מעייפות הגומיות הפנימיות זה בד"כ פנימה, לתוך הצינורות החוזרים, ואז ישנה שקיעה מהירה יותר של הרכב בעמידה עם מנוע כבוי ועוד תופעות שכאלה, אבל זה לא קשור לצינור חוזר קרוע.
בריאות לכולם!
  • שבועיים מאוחר יותר ...
שלום !
לצערי רק עכשיו קראתי שרשור זה.
מזלך שאתה לא מקשיב יותר מידי למה שכותבים כאן ופועל לפי ההגיון
אתה מציג בעיה מסויימת ומנסים לתת לך כאן פתרון לבעיה אחרת תוך תיאור בדיקת תקינות של הדוזר..
מטרת הדוזר לשמור על יציבות ומפלס הרכב בעת לחיצה על הבלם. ברגע שמרבית השמן מופנית לבלימה אין מספיק לחץ לשמור על איזון וכדי למנוע את תופעת הצניחה (בעיקר של החלק הקדמי ובעת נסיעה בירידה) מייצר היצרן פתרונות.
לחיצה על הבלם תוך הגבהת הרכב/הורדה (עם הידית) מראה שעדיפות העברת השמן לבלם היא נכונה, ולכן רק בעת הרפיית הדוושה מוסת השמן לדברים פחות חשובים כמו הגבהה/הורדה.
לפיכך ברור שהדיאנוזה שקיבלת לבצע וההנחייה להחליף הדוזר מראה שאם כל הרצון הטוב של האנשים לעזור, המלצותיהם יכולות לעלות לקורא בהוצאות מיותרות.
לפיכך הדבר הנכון הוא לגשת למוסך מוסמך לסיטרואן.
BX זה לא דגם נדיר כך שכל מוסכניק (וגם הלא מיומן) יוכל לאפיין על נקל הבעיה ולפתור אותה
בברכה,
אילן
בזמן האחרון התופעה פסקה לגמרי, אין לי שום אפשרות להסביר זאת, אולי לכלוך אולי משהו אחר אבל כל זמן שהכל בסדר אני לא נוגע.
שלום !
בברכה,
אילן
אתה חכם לאחר מעשה, אנשים פה ניסו לתת פתרונות לפי נסיונם האישי, לא תמיד זה מדויק, ככה זה כשמנסים לקבל פתרונות דרך האינטרנט.
ברור שהדבר הראשון שהוא צריך לעשות (אם הוא לא מנסה לתקן לבד את הבעיה) זה לגשת למוסך, לא בטוח שיעזרו לו שם.
BX זה לא דגם נדיר בכלל אבל מתי בפעם האחרונה ניסית להיכנס למוסך עם רכב כזה? - מסתכלים עליך כאילו נחתת מהחלל ולא ממש מאושרים לטפל לך ברכב, מה גם שמנסיון (עם 5 סיטרואנים), למוסכים לוקח זמן לאתר בעיות כאלה אם בכלל מצליחים ובדרך לוקחים לך הרבה כסף על חלקים שמחליפים ללא צורך. ולי היו 2 BX ונסיון עם 3 מובכים מורשים בצפון.
בכל מקרה, נפתרה בעיה וזה הכי חשוב.
בריאות לכולם!
