dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4403 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
נסיתי לקרוא ולתרגם את המאמר מחו"ל וממה שהבנתי הIPA אינו מסיר לגמרי ובצורה מוחלטת את האוטם צבע והווקס ואני מצטט:
Chemically Removing Waxes and/or Paint Sealants
Note this article is addressing the dilution strength for removing compounding and/or polishing lubricating oils sometimes called fillers during the paint correction steps. You can also use this to try to remove any previously applied wax or paint sealant, but while I was speaking with one of my chemists friends about this topic they told me that Isopropyl Alcohol is not effective at removing some polymer products.
Since there's no way of knowing at the molecular level what's on the surface before you wipe, and no way of knowing if 100% of everything has been removed off the surface after you wipe, therefore there's no way of knowing if IPA, (in any form) is effectively removing 100% of any previously applied wax or paint sealant. You can hope... you can assume... but you can't know 100%
If you're dead set on removing any previously applied wax or paint sealant by chemically stripping the paint, then a combination of using both a 10% solution of IPA to Water followed by wiping with Mineral Spirits should remove most, if not all, of any previously applied wax or paint sealant.
Personal Recommendation For Removing Waxes and Paint Sealants
To remove any previously applied wax or paint sealant, I recommend using a light paint cleaner or a light polish applied by hand or machine. A light paint cleaner or abrasive polish will effectively remove any previously applied wax or paint sealant AND leave the paint looking clear and glossy. I call this working forward in the process because the goal is to create beauty.
הבחור טוען שיש פתרון אחר להסרה מוחלטת של הווקס והאוטם,מה אתם אומרים?,ומה הדילול המומלץ?,11.375%,17.5% או12.5%?
