פשוט זבל, אל תבזבז את הזמן שלך.
חיפשתי קצת בנוגע לסבון. אתמול חיפשתי בעמידה בשמש בטלפון ולא מצאתי דבר, עכשיו במחשב מצאתי מספר דברים מוזרים בגוגל.
To use soap with your Muller BCMR-110 (ML-180), you need to use the dedicated detergent bottle attachment that clicks directly onto the spray gun. High-pressure washers cannot draw soap through their standard high-pressure nozzles, as physics requires low pressure to siphoning cleaning agents. [1, 2]
Step-by-Step Soap Application
  1. Fill the Bottle: Pour your chosen pressure washer detergent into the small plastic soap bottle attachment. If using a concentrate, dilute it with water according to the soap bottle's instructions. [1, 2]
  2. Attach to the Gun: Remove the standard long spray lance from your trigger gun. Snap or twist the soap bottle attachment directly onto the front of the trigger gun until it locks into place. [1, 2]
  3. Apply the Soap: Turn on the water and the machine, then pull the trigger. The pressure washer will automatically spray a thick, low-pressure soapy foam over your target surface. [1, 2, 3, 4, 5]
  4. Let it Dwell: Allow the soap to sit on the surface for 2 to 3 minutes to loosen the dirt. Do not let the soap dry completely, especially on car paint, as it can leave streaks. [1, 2, 3, 4, 5]
  5. Rinse it Off: Twist and remove the soap bottle, reattach your high-pressure spray lance, and blast the soap and grime away. [1, 2, 3, 4]
⚠️ Crucial Rule: Always Use "Pressure Washer Safe" Soap [1]
Never use liquid dish soap, laundry detergent, or household bleach in your machine. These soaps are too viscous, will create uncontrollable suds that can stall the system, and contain harsh chemicals that can destroy the internal rubber seals of your pump. Always purchase dedicated soaps labeled "Pressure Washer Safe" or "Snow Foam". [1, 2, 3, 4, 5]
System Flush (Post-Cleaning Maintenance)
When you are completely finished, empty any leftover soap from the attachment bottle and fill it with clean water. Spray the clean water through the attachment for about 30 seconds. This flushes out any remaining soap residue so it doesn't clog the small nozzle internal components while sitting in storage. [1, 2]
אלא שאין מיכל סבון חיצוני שמתחבר למתז אלא מיכל סבון פנימי...
ובמקום אחר דווקא כתוב "אביזרים נלווים: אקדח / צינור 5M / קנה התזה בעל לחץ פיזור משתנה / פיית טורבו / סנן כניסה / בקבוק לחומר ניקוי.
עריכה אחרונה על ידי Haim_gds
תוספת
הגב לנושא זה...
  Only 75 emoji are allowed.
