חדשות רכב - מזדה.
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7864 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
תשימו לב שרשום RX8 MPS..
לדעתי הMPS מציין את הגג החשמלי, לעומת הRX7 שאין לה גג חשמלי :roll:
Mx-5.
תוצג ב-05.
.Mid 2005, and that is definitely one of the worst photoshop jobs I have seen so far
Rx-7.
תוצג לקראת 06.
That is still unconfirmed, and that Photoshop job that you look at somehow manages to be even worse than the Miata.. truly amazing
Rx-8 MPS.
תוצג לקראת 06.
תצוייד במנוע שמופיע ב-6 MPS , המספקת 300 כ"ס.
It's been a while since I have seen so many mistakes in the same sentence... you obviously have no idea what the R in the name RX8 stands for and that is Rotary... last I checked the Mazda 6 it did not have a rotary and my sources at Mazda tell me that there are no plans for productioon of a rotary-powered 6.... further more, the Mazdaspeed 6 is an AWD which I HIGHLY doubt the RX will ever be, not to mention that it does not make 300HP but 270HP
Lastly, the RX8 does not replace the RX7 in the company's line-up but is an addition to it as an alternative 4 seater which the RX7 will never be
.Moti
לפי מה שהבנתי לRX7 דווקא יש מושב אחורי בעל מרווח רגליים נדיב. :roll:
Having driven all three generations of the RX7 and almost buying them twice, you certainly never saw an RX7 in your life... even the third generation - the FD, isn't much bigger than my miata inside... here are pix of the FD, see if you can find the place for a back seat yourself
:razz: ... NOT
:wink: .Moti
אופס :oops: התבלבלתי עם הRX8.. פאדיחות :oops:
