Audi A3 Strange Engine RPM
X-Kent
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7929 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
Hi.
I have bought an audi a3 4 days ago and I have a very strange engine behavior.
When I switch the engine on, it's rpm is jumping between 0.5RPM~1.2RPM.
It is nothing critical but it should not be that way.
The other thing, is for example I drive at 3th gear, then drop to nutral and start braking then it appears again. RPM start to jump at the same range...
What may it be? Should I rise engine RPM?
Vehicle specs:
audi a3 1.8 turbo
1998
at a buying check at "mahon elisha" they said that engine is in perfect condition.
I have a check report with some data on it, if you tell me what exactly may help you tell me I will type it here (or maybe scan the document)
Regards.
In the perfect world without walls. What for you need Windows and Gates?
PS: Yes I can read hebrew.
חבל על הזמן ניקוי מד זרימת אויר ברכב לא יפתור את הבעיה
אתה צריך להתחבר למחשב לעשות דיאגנוזה ואז תדע בוודאות אם אתה מעוניין צור איתי קשר
03-5702345 ביום ראשון הדיאגנוזה ללא חיוב
שבת שלום
שבת שלום
Thanks man, I will call you at sunday.
A friend of my (a mechanic known as gsi16v in the forum), checked the car and did not find the problem. If you say you may give me a free diagnostics I will of course accept your offer with pleasure and ofcourse pay you for the repair/cleaning needed to fix this.
It is my first good car(after two daewoos :-) so I want it to run as smoothly as possible.
Talk to you at sunday. bye for now.
anyone esle that have any suggestions is welcome.
