גודל צמיגים ישנים
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6604 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
sorry abou the english but this is the best i can do for now
on the רישיון
of my 71 peugeot 304 cabriolet it says
175/70/14
on the car itself i have 165/70/14
i went yesterday to do the test at the test place in beit shemesh the
man told me i have to put on 175/70/14 to pass the test
now if you put on 175/70/14 tires on a peugeot 304 it wont move the tires would hit the tire well
After much research i ended up at Punksheria in ashdod
he had the full book of tire sizes from misrad hatchbura from 1975
under peugeot 304 1971 the tire size is 145/14
he explained to me that this is an old tire size which is no longer made but the closest
tire size available is 165/70/14
this give the same ride height
apparently the calculation is as follows
the number 145 represents 14.5 cm
this is the width of the tires
in the old tires there was no middle number to tell you the height but it assumed to be 80%
of the width
which comes to 11.6
now if you multiply 11.6 by 2 you get the tire height which is 23.2 (+14 inches) now
the 165/70/14 tires height is only 70% of the width meaning it is 16.5 x .70 x 2 = 23.1
so basicly according to the pucteria in ashdod the correct replacement for a 145/14 is the 165/70/14
I took the documentation to the test in beit shemesh he approved the change and the car passed the test and he made the change in the rishayon
I just wanted to check if any one could confirm this calculation
and if so provide important information for other users
best regards
Aron
If at first you dont succeed
Dont try ski diving
נתקלתי בבעיה דומה עם החלפת הצמיגים של המוסטנג.
ברשיון היה 695 על 14...
שיניתי את זה למידה אחרת מודרנית והרכב עבר את הטסט (לאחר בירור אצל הבוחן)
ברשיון של הפיז'ו שלי (דגם זהה, שנת 73) עדיין רשום 145/14.
לפני הטסט (שבסוף לא עשיתי כי התחלתי את השיפוץ) ניגשתי לכמה פנצריות בירושלים, בתלפיות, וכולם אמרו לי שהמידה עדיין קיימת, וזה יקח יום עד שהצמיגים יגיעו במיוחד מתל אביב (והמחיר זהה לצמיג שיש לך עכשיו ברכב).
סתם לידע כללי,
שחר
פורד אנגליה 1963 95% מושלמת
פיז'ו 304 קבריולט 1973
מועדון פורד אירופה
