|למכירה| רדיו דיסק KENWOOD KDC-M9021SE
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7296 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
מפרט טכני:
Fully motorized D Mask+ with Mask key
4 x 50 W
3 preouts
RDS Tuner
3 colour, Full DOT FL display
DMask+
MP3 decoder built-in
Rotary volume control
Changer control
Remote control included
4 x 50 Watt max output power
3 RCA preouts, 4.5 Volt
Separated tone control: Bass/Mid/Treble
Source tone memory / Loudness control
System Q-EX: preset & full manual sound control
AUX-in with optional unit (CA-C1AX or KCA-S210A)
System E’s (built-in easy LPF & HPF)
Bass Management System with compatible amp.
Dual zone source & volume control
K3I clean reception tuner
RDS Tuner with Radio Text
24 presets: 18 FM, 6 MW & LW
Auto memory entry (AME)
Up/down seek tuning / Local Seek
Stereo/Mono selector
Auto1/Auto2/Manual tuning mode
DAB reception with optional unit KTC-9090DAB
CD-R/RW ready
MP3 decoder built-in with support of ID-3 Tag
MPEG-1.0/2.0/2.5 Audio layer-3
Random/Repeat/Scan function
CD-Text ready
0-bit mute (L&R independent)
8 times over-sampling
1 bit D/A converter
S/N ratio: 105 dB
Dynamic range: 93 dB
Channel separation: 95 dB
Dual changer control capability (CH1/CH2 & AUX)
CD-text with compatible units
DNPS (Disc Name Preset) with compatible units
DNPP (Disc Name Preset Play) by remote control
Direct access with remote control
Disc & Track repeat
Disc & Track scan
Disc & Magazine random play
Motorized angle adjustment
Protection case for faceplate
3D Multicolour FL display (4-tone)
Selectable key illumination (Red or Green)
Digital clock (24H) / Auto dimmer
All Off select (20/40/60 minutes)
Built-in fuse/coil
2-way telephone mute
Memory Calendar
External option control
OEM display out
OEM steeringwheel wired remote input
Kenwood H/F GSM interface with optional unit
Remote control included (RC-420)
מכשיר פשוט סוף הדרך! רציניים בלבד לפרטי!
