החלפת שמנים , ההבדל הגדול
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7459 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
עדיין כואבת לי הבטן (ולא בגלל FALOU).
Oil Change instructions for Women:
1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the
last oil change.
2) Drink a cup of coffee.
3) 15 minutes later, write a check and leave with a properly maintained vehicle.
Money spent:
Oil Change $20.00
Coffee $1.00
Total $21.00
Oil Change instructions for Men:
1) Wait until Saturday, drive to auto parts store and buy a case of oil,
filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
2) Stop by 7 - 11 and buy a case of beer, write a check for $20, drive home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process.
Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench
15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
16) Crawl out from under car with dripping oil filter splashing oil
everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties. Drink a beer.
17) Buddy shows up; finish case of beer with him.
Decide to finish oil change tomorrow so you can go see his new garage door opener.
18) Sunday: Skip church because "I gotta finish the oil change." Drag pan full of old oil out from underneath car. Cleverly dump oil in hole in back yard instead of taking it back to Kragen to recycle.
19) Throw kitty litter on oil spilled during step 18.
20) Beer? No, drank it all yesterday.
21) Walk to 7-11; buy beer.
22) Install new oil filter making sure to apply a thin coat of oil to gasket surface.
23) Dump first quart of fresh oil into engine.
24) Remember drain plug from step 11.
25) Hurry to find drain plug in drain pan.
26) Remember that the used oil is buried in a hole in the back yard, along with drain plug.
27) Drink beer.
28) Shovel out hole and sift oily mud for drain plug. ?Re-shovel oily dirt into hole. Steal sand from kids sandbox to cleverly cover oily patch of ground and avoid environmental penalties. Wash drain plug in lawnmower gas.
29) Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
30) Drink beer.
31) Crawl under c ar getting kitty litter into eyes. ?Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame.
32) Bang head on floorboards in reaction to step 31.
33) Begin cussing fit.
34) Throw stupid crescent wrench.
35) Cuss for additional 10 minutes because wrench hit bowling trophy.
36) Beer.
37) Clean up hands and forehead and bandage as required t o stop blood flow.
38) Beer.
39) Beer.
40) Dump in five fresh quarts of oil.
41) Beer.
42) Lower car from jack stands.
43) Accidentally crush remaining case of new motor oil.
44) Move car back to apply more kitty litter to fresh oil spilled during steps 23 - 43.
45) Beer.
46) Test drive car.
47) Get pulled over: arrested for driving under the influence.
48) Car gets impounded.
49) Call loving wife, make bail.
50) 12 hours later, get car from impound yard.
Money spent:
Parts $50.00
DUI $2500.00
Impound fee $75.00
Bail $1500.00
Beer $40.00
Total - - $4,165.00
But you know the job was done right!
הייתי מחפש את המייל הזה אבל בקיצור:
נגיד וצריך לקנות את מוצר Y מחנות X
1. הולכים לחנות X
2. לוקחים את מוצר Y
3. משלמים
4. הולכים הביתה
אתן לעומת זאת:
1. נכנסות לחנות Z
2. מסתובבות חצי שעה (אני אופטימי)
3. נכנסות לחנות Z
4. מסתובבות חצי שעה (אני אופטימי)
5. נכנסות לחנות T
6. מסתובבות חצי שעה (אני אופטימי)
7. נכנסות לחנות V
8. מסתובבות חצי שעה (אני אופטימי)
9. נכנסות לחנות S (כן, אני מושפע מאלגברה)
10. מסתובבות חצי שעה (אני אופטימי)
11. נכנסות לחנות X (מזל טוב)
12. מסתובבות חצי שעה
13. מגיעות למוצר Y
14. בדרך לוקחות עוד כמה מוצרים
15. משלמות
16. הולכות הביתה
אתן לעומת זאת:
1. נכנסות לחנות Z
3. נכנסות לחנות Z
נפלת על חנות חח"ע ועל?
המשך ל-15
16. נכנסות לרכב
17. מכוונות את המראות לפרצוף לראות אם האיפור מסודר
18. נוסעות עד הרמזור הקרוב
19. מריחות משהו שרוף
20. משחררות בלם יד
21. בודקות סומק, פודרה, איי-ליינר, אודם
22. שומעות צפירות מאחורה.
23. ירוק - נוסעת הבייתה.
1f u c4n r34d th1s u r34lly n33d t0 g37 l41d
לא לא לא - זה הולך ככה.
1. נכנסות לקניון במטרה לקנות מסטיק אורביט וחזיה
2. עוברות ליד חנות בגדים
3. נעצרות מולה כדי להסתכל על הבובות בחלון הראווה בעוד שאנחנו חושבות "רבאק, עוד 4 קילו ואני אהיה מספיק רזה..."
4. נכנסות לחנות במטרה "סתם להסתכל"
5. מודדות כל פריט במידה שלנו ולבסוף מוצאות איזו חתיכת בד שמישהו קרא לה חצאית\חולצה למרות שאין בה מספיק בד כדי להכין ממנה חוטיני
6. מסתכלות על תגית המחיר - "ממממ, 139.90 - פששי - זול!!! אני לוקחת!!!"
7. מגיעות לקופה
8. משלמות
9. יוצאות מהחנות עם חיוך מאוזן לאוזן (כאילו קיבלנו הרגע--מחמת עודף הורמונים אני אשתוק--)
10. ממשיכות ללכת
11. עוברות ליד עוד חנות בגדים
12. חוזרות על סעיפים 3-9.
13. הולכות לקנות פרי-שייק: בננה מנגו מלון פסיפלורה על בסיס תפוזים עם תוספת ליצ'י, פקאן מסוכר ומקופלת לבנה
14. יוצאות לעשן
15. עוברות ליד חנות נעליים
16. נכנסות פנימה
17. עוברות על כל החנות
18. אחרי שעה וחצי מחליטות שלא בא לנו בכלל לקנות נעליים
19. יוצאות משם וממשיכות ללכת
20. עוברות ליד חנות בגדים
21. חוזרות על סעיפים 3-9 (ניתן לחזור על הסעיפים N פעמים ביחס ישר למספר חנויות בגדי הנשים באזור)
22. קולטות את חנות הלבנים
23. נכנסות אל החנות בהרמת חזה ("הציצים שלי יותר גדולים נה נה בננה")
24. מודדות 3 חזיות
25. קונות 2 מהן ועוד ערימה של תחתונים וגרביים.
26. מסע הקניות הוכתר בהצלחה יתרה - אפשר ללכת הבייתה.
27. מגיעות הבייתה - "שיט!! שכחתי את המסטיקים!!!"
ככה זה הולך בערך...
יש אנשים שמוציאים ממך את המיטב, אנשים נפלאים ונדירים. אני קוראת לו אהובי - אסף.
כשגבר עושה קניות לוקח לו יותר זמן מאשה.
אולי היא מודדת 4 שעות גופיה ונעלייים ובסוף קונה את הכל, אבל שליפת הויזה אורכת חלקיק השניה בלבד.
מיצד שני כשגבר הולך לקניות (אם ביכלל..) , הוא מראש יודע מה הוא קונה אבל להוציא את הארנק מהכיס זה 7 שעות
27) Drink beer.
30) Drink beer.
36) Beer.
38) Beer.
39) Beer.
41) Beer.
45) Beer.
ככה זה הולך בערך...
פספסת סעיף באמצע...
27. נכנסות לאוטו ותוך כדי הנסיעה בודקות מה הן קנו, תוך שליחת היד למושב האחורי וקריאה של הקבלה.
28. גורמות לגברים הנוהגים במכוניות לידם לסטות מנתיבם עקב זגזוגן ימינה ושמאלה על הכביש ולעשות תאונות.
29. קוראות מחר בעיתון שגברים גורמים ליותר תאונות מנשים.
חלומות נועדו להתגשם
http://www.BackOnTwo.com
בוריס, זה שאתה קמצן לא אומר שכולם ככה, תמשיך לחסוך בברקסים, קארט 12 לא עוצר!
עדיין אני לא מבין מה קשור בוריס (לא דני) ו - קארט, (חוצמזה ש 12 עכשיו כן עוצר)
בכל מקרה הויזה שלי מזמן לא אצלי ובארנק יש רק טלכרט (זה במקום מפתח לאינטרקום)
אז אם הייתי קמצן הייה מסגיר ליידי את הויזה ובמקום טלכרט הייתי משתמש בכרטיס של קופת חולים.
