Helix P SIX DSP MK2
Themanwithnoname
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 3068 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
  • New “Ultra HD Class D” concept which combines the high-end sound quality of Class AB technology with the benefits of Class D amplifiers
  • Full audio bandwidth up to more than 40 kHz thanks to 96 kHz sampling rate
  • Cutting-edge, extremely powerful “fixed point” Audio DSP with 64 Bit resolution and 1.2 billion MAC operations per second
  • 24 Volts compatible without the need to make any changes to the unit
  • Six speaker outputs with up to 230 Watts RMS into 2 Ohms
  • Two processed RCA outputs
  • Inputs: 6 x RCA, 6 x Highlevel with up to 20V RMS input sensitivity, optical SPDIF input
  • Smart highlevel input with ADEP circuit
  • HELIX Extension Card slot (HEC) for additional input / output modules like Bluetooth® Audio Streaming, High Resolution Audio Streaming via USB etc.
  • Compact design with low heat dissipation thanks to ­extraordinary efficiency
  • Automatic Remote switch
עריכה אחרונה על ידי Themanwithnoname
Hu: iPad 2 64gb 3G Signal Extractor no DAC (Toslink digital): cambridge audio ID100 @
Processor: Alpine H701 @ 3-amps: Zapco competition C2K-4.0X.P ,C2K-3.0XP,@
Component 3-way: Sinfoni S Mono Amp: Pantera one @ Sub: HX300D
