dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 8581 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
קומפוננט זה רמקולים שכל חלק שלהם בא לחוד .
היותר נפוצים באים בשני חלקים, מיד וטוויטר (יש גם כאלה שבאים עם וופר).
לכולם יש קרוס אובר שמפצל את התדרים הגבוהים לאן שצריך (טוויטר) ואת התדרים הנמוכים יותר למיד.
ומה שטוב בו הוא שכל רמקול מוציא תחום תדרים ספציפי שהוא תוכנן לעבוד בו.
אלמנטים נפרדים - ערובה לאיכות גבוהה יותר, בד"כ...
Component speakers generally consist of 3 pieces, a midbass speaker generally either 5 1/4 or 6 1/2 inches, a tweeter, and a crossover to seperate and send the signals to their appropriate places. Sometimes you may even see 3 piece speaker systems where either an 8" or 6.5" speaker is configured for bass, and the others are for midbass and highs. Bass is generally regarded as the lower frequiences, such as drums, or lows, Midbass handles the mid frequiencies liek the gituars and to an extent the voices, and the tweeters for the highs deal with the upper level vocals, symbols, etc. These speakers are generally placed into the kick panels of your vehicle to get a better soundstage, ideally, you'd like the sound to come from infront of you, a good Midbass config will make it feel as if the bass is coming from infront of you, when in reality it is from behind you! Once again, if you want to go this route and do a kickpanel install you can get custom kickpanels for your vehicle from Q LOGIC or, you can roll up your sleeves, break out the fiberglass and make your own!
Once again, yo uget what you pay for, when it comes to speakers and it is not uncommon to spend 250-600$ on a great set of components, DEI (studio series) CD tech, Diamand, MB Quart, and Focal all make some pretty serious proudcts! But as always try to audition the components and let your ears do the judging!
Coaxials are designed to be a direct replacement for your stock speakers, they will fit in your stock speaker locations, and generally can sound alot better then what you have, especially if you have an older vehicle. While not as effective as components, Coaxial speakers can still sound great, some companies to look into are Infinity, JL...
מאמר קטן :wink:
MCS 2008
