dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6451 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
למכירה מרצדס יונימוג על שלט
ישנו פירוט רק מי שרציני להתקשר מחיר מבוקש 3000 שקל ייתכן ותיהיה הנחה משמעותית
דבר נדיר מאוד
לפרטים 0544855534 חדש מהניילון!!!!!!
להלן הפירוט:
הפירוט באנגלית כיוון שהרכב יובא מחו"ל
DESCRIPTION
  • R/C fans have long been modifying their machines into rock crawlers. Tamiya has followed this growing segment with interest and we are now proud to present to you the fruits of our research.
    * The Mercedes-Benz Unimog's body is made from lightweight polycarbonate material.
    * CR-01 chassis features a heavy-duty ladder frame with strong lightweight pressed aluminum channels and cross channels.
    * 4 link coil suspension provides the flexibility needed to conquer difficult rocky terrain.
    * Center gearbox features planetary gears with a compact design enabling the battery to be mounted lower for a better center of gravity.
    * Newly designed 3-piece beadlock wheels mounted with massive 125mm diameter and 6mm wide rock crawler tires are ready for any terrain.
    * Powered by a 540 motor.
    * Can be fitted with Yellow (Front) and Red (Rear) TLU-01 LED Lights (ITEM 53909)
    * The Unimog is compatible with a wide range of Option Parts
    ELECTRIC KITS REQUIRE:
    (unless stated differently above)
    * Radio: 2-Channel with servo(s) and ESC
    * Battery: 6-cell flat with standard Tamiya connector
    * Charger: AC/DC timed or peak for 6-cell battery
    * Paint: PS for Polycarbonate/TS for ABS
    * Misc. Items: Building and track equipment
