880PRS. HELIX COMPETETION A6. JBL GTI
Soundman
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6527 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
למכירה מערכת של חבר! אני מדגיש. הציוד לא שלי.
המחירים גם לא שלי. ואני יעדכן את המודעה כאשר יהיו לי יותר פרטים.
HU. פיוניר 880PRS. מחיר 1800 שקל
מגבר HELIX COMPETETION A6. מחיר מבוקש. 4500 שקל.
PinaLeft1.jpgDriver with class A technology
Outputstage with 24 MosFet transistors
RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
NFI (noisefree input) for distortion-free listening
Mono/Bridged/ Stereo switch
8.0 volt input for connection to any signal source
ADC - Anti Distortion Choke to eliminate distortions
Intelligent temperature and power controlled switching power supply
Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
CPS - Color Protection System
SMD - Surface Mounting Devices for constant assembling quality
Double-sided, extra strong (2x 110u) and copper plated pc-board for best power and signal transmission and protection against vibrations
24-karat gold-plated solid connectors suitable for 25 m²/ gauge 4 cables
Temperature-optimised heatsink for highest efficiency
1% accurate components for perfect audiophile sound quality and maximum power
Smoked-grey plexi cover with both side printing
Technical Data:
Cont. power rating RMS/Max. power at 4 Ohms RMS/12 V 6 x 60 Watt
Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V 6 x 75/130 Watt
Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V 6 x 125/215 Watt
Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V bridged 3 x 220/350 Watt
Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V bridged 1 x 400/640 Watt channel C/D
Cont. power rating RMS/Max. power at 1 Ohms RMS/13,8 V bridged 2 x 200/320 Watt channel C/D
Total harmonic distortion
Signal to noise ratio > 100 dB
Damping factor > 450
Frequeny range 20 Hz -20 kHz
TIM distortion
Input sensitivity 500 mV - 8 V
Fuse 4 x 20 A
Input impedance: 10 kOhm
Dimensions (HxWxD) mm 35 x 240 x 500
Weight netto 5,5 kg
סאב של JBL משנת 2002. דגם GTI. שני סלילים! מחיר 1500 שקל (עלה בזמנו כ 2500 שקל)
דגם אני מקווה להביא בקרוב
מי שיקנה את כל המערכת קומפלט יקבל מתנה. קומפוננט של MBQ. סדרה יחסית גבוהה.
מחיר כולל. 6500 שקל. במקום 7800. ועוד קומפוננט של MBQ.
לפרטים. בין השעות 10:00 ל 18:00 בלבד!!
ל4142525 050
גלגלצ: דיווחי תנועה ביציאה ממצרים. עומס תנועה ענקי ממחלף סיני עד מחלף ים סוף, משה תיזמן 40 שנה. תודה לך משה.
מודעת מכירה ................ פרויקט איטום על הרכב שלי
  • שבועיים מאוחר יותר ...
  • 4 חודשים מאוחר יותר...
מוקפץ.
הציוד יושב בבית כבר כמה חודשים מחכה לקונה.
מחיר מגוחך.
מספר חדש !! לא לצלצל לישן. הוחלפו הבעלים (טלפון חברה)
351140 0503
מחיר של 6000 שקל.
לגבי הקומפוננט והסאב אני ינסה שוב לברר לכל השואלים.
שזה מחיר של ה A6 חדש לבד!
