למכירה מגבר 5 ערוצים ALPHASONIC
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5782 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
Alphasonik PMZ12005A 5-Channel Class A/B Car Audio Amplifier
5-Channel Class A/B Bipolar Power Amplifier
RMS Power Rating: 75 watts x 4 chan. + 200 watts x 1 chan. at 4 Ohms Stereo
RMS Power Rating: 120 watts x 4 chan. + 320 watts x 1 chan. at 2 Ohms Stereo
RMS Power Rating: 150 watts x 2 chan. at 4 Ohms Mono
RMS Power Rating: 320 watts x 1 chan. at 4 Ohms
Bridgeable
Tiffany-style input and ouput RCA jacks
RCA and Speaker Inputs(Low/High Level)
MOSFET high speed switching power supply
THD: 0.06%
S/N Ratio: >100dB
Frequency Response: 5Hz-50kHz
Variable High Pass/Low Pass Filter: 50Hz-250Hz, 18dB/oct
Variable Subsonic Filter: Off-20Hz, 18dB oct
Variable Bass Boost at 45Hz: 0-18dB
Variable Phase Shift: 0-180 degrees
Input Impedance: 10K ohms
4-way protection circuitry: thermal, short circuit, overload and DC offset
Direct input terminal/PCB contact
Dimensions: 18 15/16L x 9 1/4W x 2H
