תנאים להפעלת מערכת Start Stop
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 2210 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
The car has not reached approx. 10 km/h(6 mph) after starting.
After a number of repeated auto stops, speed must again exceed approx. 10 km/h(6 mph) before the next auto stop.
The driver has unfastened the seatbelt.
The capacity of the starter battery is below the minimum permissible level.
The engine is not at normal operating temperature.
The ambient temperature is under -5 °C or above approx. 30 °C.
the windscreen's electric heating is activated.
The environment in the passenger compartment deviates from the set values.
the car is reversed.
The starter battery's temperature is below or above the permitted limit values.
The driver makes sweeping steering wheel movements.
The road is very steep.
The bonnet is opened.
The gearbox is not at normal operating temperature.
When driving at high altitudes when the engine has not reached operating temperature.
The gear selector is in ± position
The ABS system has been activated.
In the event of heavy braking (even without the ABS system having been activated).
Many starts during a short period of time have activated the starter motor's thermal protection.
Applies to cars with diesel engines: The exhaust system's particulate filter is full.
A trailer is connected electrically to the car’s electrical system.
S60 Rdesign
