דוח תוכנת VAGCOM
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5773 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
שלום וחג שמח!
ביצעתי סריקה כללית ברכ לאחר החלפת מצערת
מישהו יודע מה זה אומר?
רכב בורה 2002 APK 2.0
תודה!
להלן הדוח
VCDS-Lite Version: Release 1.0
Wednesday, 29 September 2010, 14:29:50:0
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine Labels: Redir Fail!
Controller: 06A 906 018 FK
Component: 2.0l R4/2V MOTR AT V04
Coding: 00033
Shop #: WSC 01317
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01M-927-733.LBL
Controller: 01M 927 733 JQ
Component: AG4 Getriebe 01M 4829
Coding: 00000
Shop #: WSC 00000
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0022530
Shop #: WSC 01317
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01317
2 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
37-10 - Faulty - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 02
Coding: 12855
Shop #: WSC 01317
Address 17: Instruments Labels: 1J0-920-xx5-17.LBL
Controller: 1J5 920 806 C
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 01102
Shop #: WSC 00000
WVWZZZ1JZ2W174196 VWZ7Z0A3795948
6 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
01315 - Transmission Control Module
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 01317
7 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799
Component: 1M Komfortgerבt HLO 0001
Coding: 00259
Shop #: WSC 01317
3 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
End --------------------------------------------------------------------------------------------------
ניראה שיש תקלות רק לגבי הבקרת אקלים והחלונות/נעילה בדלתות
כתובות 19 ו 17 איתם הוא נכשל בתקשורות כניראה לא רלונטיות לרכב שלך
בכתובת 19 מופיע פרוטוקול CAN שרכבך משנת 2002 לא אמור לתמוך.
לפי הקטע הזה כניראה שאין בעיה "מחשבית" בגיר
Coding: 00000
Shop #: WSC 00000
זו יכולה להיות גם בעיה מכנית שלא תבוא לידי ביטוי במחשב. או שיש צורך בעדכון גירסת תוכנה.
