dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5873 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
שלום רב.
קיבלתי רכב חילןפי מחברת הליסינג - פורד פוקוס לדעתי שנת 2008 .
יש רדיו מקורי ברכב- צירפתי תמונה שלו.
ברדיו יש כפתורים שנראים כאילו אפשר לחבר אליו את הטלפון הנייד. האם מישהוא יודע איך לעשות זאת.
לי יש בלאקברי.
Ok, what you need to do is:
• Make sure bluetooth is switched on on your phone
• Go through your phones bluetooth menu, make sure your phone is shown as "visible", not "hidden"
• Know your phones bluetooth individual name so you know that it is your phone when you activate it with your stereo, ie "Dave", or "K800i" etc...
• Then you need to make sure that you have space left on your stereo to accept your phone. Simply, this means that your stereo probably has, for example, six spaces/phones it can store at once on its memory. If people have used your stereo before you, it stands a chance that the memory is full. Therefore, you need to "debond" the existing phones from the stereos memory.
To do this, depending on the make of your stereo, you need to play around with the phone menu. Find out how to debond and get rid of existing stored phones.
• Whilst going through the menu, make sure in your settings, bluetooth is switched on/activated, and all other settings are switched on and correct in order for you to use bluetooth.
• Then, put the stereo back to its "desktop" as it were, ie, the normal screen.
• Get your phone, go to bluetooth menu, scan for "new devices", this should hopefully now find something like "Ford Audio".
• Now, if it asks you for a four digit pin code, every time I have done this (loads of times!), the pin code has been 0000. I realise you may have tried and failed with this, but go through the steps above incase something has been missed, then try it again.
• On a successful pincode being entered, your phones bluetooth name will come up on the stereo display, and your phone will be "bonded" with your stereo for bluetooth usage.
I have always used 0000 as the pincode, and I am unaware what to do if all steps have been remedied and the pincode still fails. Hope this gets it working for you.
If you still have difficulties, let me know exactly the model of stereo you have and I will see if I can help further.
Thanks
טוב שם טוב משמן טוב
Thanks
נשמע לי מגוחך לחשוב שבפוקוס ליסינג יש דיבורית BT מובנית
Auto Emoción
הדגם הספציפי הנל יש יכולות BT שעובדות בחו"ל ,אם בארץ הפשיטו אותו ממקלט ה BT זה כבר סיפור אחר.
כבר יש בארץ דגמי ליסינג עם תוספות שבעבר לא האמנת שתקבל בחינם [לדוגמא ב I30 כניסה ל MP3 מובנית].
טוב שם טוב משמן טוב
הכפתורים הללו אינם שמישים ברכבך.
הרכב הראשון והיחידי בנתיים שהגיע עם מערכת בלוט'וס הכוללת שמיעה מהפלאפון ודיבורית הוא בפורד EDGE שהגיעו ארצה בארבעת החודשים האחרונים ואילך.
