dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 1530 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
תקלת מנוע מזה אומר?
Car Scanner ELM OBD2
DTC report
Selected brand: Ford
============1==============
P0135
Raw code: 0135
ECU: Engine control unit
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction
Ford: Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
============2==============
P1131
Raw code: 1131
Status: Confirmed
OBDII: Lack Of HO2S Switch - Sensor Indicates Lean
Ford: Lack Of HO2S11 Switch - Sensor Indicates Lean; Lack Of HO2S Switch - Sensor Indicates Lean
============3==============
B10AC(00)
Raw code: 90AC00
ECU: Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
============4==============
P0135(00)
Raw code: 013500
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============5==============
P0571(00)
Raw code: 057100
OBDII: Cruise control/brake switch A - circuit malfunction
Ford: Cruise Brake Switch Circuit Malfunction
============6==============
P1131(00)
Raw code: 113100
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============7==============
P2121(00)
Raw code: 212100
OBDII: Throttle position (TP) or Accelerator pedal position (APP) sensor/switch D - range/performance problem
============8==============
U0101(00)
Raw code: C10100
OBDII: Data bus, transmission control module (TCM) - no communication
============9==============
U0129(00)
Raw code: C12900
OBDII: Data bus, brake system control module - no communication
============10==============
U0167(00)
Raw code: C16700
OBDII: Data bus, immobilizer control module - no communication
============11==============
B1024(00)
Raw code: 902400
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
============12==============
B2141(00)
Raw code: A14100
Ford: NVM Configuration Failure
============13==============
P0010(00)
Raw code: 001000
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
============14==============
P0011(00)
Raw code: 001100
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
============15==============
P0012(00)
Raw code: 001200
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded
============16==============
P0016(00)
Raw code: 001600
OBDII: Crankshaft position/cams
בס"ד
על פניו, נראה שיש תקלות ישנות בדו"ח שהעלת, תמחק את התקלות ותראה מה נשאר.
אני קם כל בוקר בשביל הילדים, בלעדיהם הייתי קם בצהריים...:lol:
