Nstil
כל מה שפורסם על ידי Nstil
  1. תקלת מנוע מזה אומר? Car Scanner ELM OBD2 DTC report Selected brand: Ford ============1============== P0135 Raw code: 0135 ECU: Engine control unit Status: Confirmed OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction Ford: Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1) ============2============== P1131 Raw code: 1131 ECU: Engine control unit Status: Confirmed OBDII: Lack Of HO2S Switch - Sensor Indicates Lean Ford: Lack Of HO2S11 Switch - Sensor Indicates Lean; Lack Of HO2S Switch - Sensor Indicates Lean ============3============== B10AC(00) Raw code: 90AC00 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle ============4============== P0135(00) Raw code: 013500 ECU: Engine control unit Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction Ford: Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1) ============5============== P0571(00) Raw code: 057100 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Cruise control/brake switch A - circuit malfunction Ford: Cruise Brake Switch Circuit Malfunction ============6============== P1131(00) Raw code: 113100 ECU: Engine control unit Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested OBDII: Lack Of HO2S Switch - Sensor Indicates Lean Ford: Lack Of HO2S11 Switch - Sensor Indicates Lean; Lack Of HO2S Switch - Sensor Indicates Lean ============7============== P2121(00) Raw code: 212100 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Throttle position (TP) or Accelerator pedal position (APP) sensor/switch D - range/performance problem ============8============== U0101(00) Raw code: C10100 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Data bus, transmission control module (TCM) - no communication ============9============== U0129(00) Raw code: C12900 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Data bus, brake system control module - no communication ============10============== U0167(00) Raw code: C16700 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Data bus, immobilizer control module - no communication ============11============== B1024(00) Raw code: 902400 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============12============== B2141(00) Raw code: A14100 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle Ford: NVM Configuration Failure ============13============== P0010(00) Raw code: 001000 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction ============14============== P0011(00) Raw code: 001100 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance ============15============== P0012(00) Raw code: 001200 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded ============16============== P0016(00) Raw code: 001600 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Crankshaft position/cams
