NAKAMICHI + JBL
canonball
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4615 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
1. מגבר JBL GTO1004
Grand Touring Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost)
Bridgeable operation
Preamp RCA outputs
Cast-aluminum heatsink
Variable high-pass filter (32-320 Hz, 12 dB/octave)
Variable low-pass filter (32-320 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 10-100000 Hz
Dimensions: 18-9/16"L x 10-3/8"W x 2-1/8"H
2. מגבר NAKAMICHI PA2100
Power Output RMS @ 4 ohms 100 W x 2
Power Output RMS @ 2 ohms 200 W x 2
Bridged Output RMS @ 4 ohms 350 W x 1
Frequency Response 20 Hz – 20,000 Hz
Crossover (Butterworth) HP 15 – 400 Hz
LP 40 – 400 Hz
Bass EQ @ 45 Hz 0 – 12 dB
S/N Ratio >90 dB
Total Harmonic Distortion
Dimensions
320 (W) x 63 (H) x 268 (D) mm
12.59 (W) x 2.48 (H) x 10.55 (D) inches
עומרי
  • שבועיים מאוחר יותר ...
