מונובולוק JL AUDIO A1800
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 2110 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
מגבר מונו לסאב
אפשרות להחלפה בציוד מעניין
יד ראשונה מרופא
ליאור 0544952254
A1800 A Series 1-Channel Class D Car Amplifier RMS Power Rating: 4 ohms: 640 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. Max power output: 2000 watts x 1 chan. MOSFET power supply Remote bass level input (remote level control sold separately) LED power and protection indicators Tuned Bass EQ (0-6 dB bass boost) Single channel operation Differential-Balanced input Topology for superior noise immunity Preamp RCA outputs Heavy duty aluminum alloy heatsink Silver-plated RCA level inputs Variable low-pass filter (40-200 Hz, 12 dB/octave) Frequency response: 10-250 Hz Dimensions: 15.75"L x 9.25"W x 2.50"H Power Specifications - Full Range Channels RMS Power @ 4 ohms 640 watts x 1 channels RMS Power @ 2 ohms 1000 watts x 1 channels Power Specifications - Subwoofer Channel RMS Power @ 4 ohms RMS Power @ 2 ohms RMS Power @ 1 ohm Power Specifications - Full Range Channels Peak Power @ 4 ohms Peak Power @ 2 ohms Peak Power @ 1 ohm Bridged Peak/Max Power Power Specifications - Subwoofer Channel Peak Power @ 4 ohm Peak Power @ 2 ohms Peak Power @ 1 ohm Amplifier Specifications Amplifier Series Marine Certified Amplifier Class D Number of Channels 1 - Mono Total Peak Power Output 2000 watts Total RMS Power Output 1000 watts Maximum Input Gauge Size Minimum Impedance Unbridged 2 ohms Minimum Impedance Bridged Not Bridgeable THD at Rated RMS Power 1% Speaker Level Inputs No Preamp Outputs 1 pair Built-in Crossover Low-Pass (LP) Low-Pass Crossover Frequency 40 - 200 Hz Signal-to-Noise Ratio 95 dB Bass Boost 0 - 6 dB Bass/Gain Remote Optional (Accessory required and sold separately) Fan Cooled No Fuse Rating 80A x 1
עריכה אחרונה על ידי lior-cti
