בולמים של KYB
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5995 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
מישהו מכיר משווק של בולמי KYB ?
אני לא ממש מצליח למצוא מישהו שמוכר אותם...
דוד
HU - RFX 9210
AMP - SONY XM-222
SPL 500W MONOBLOCK
REAR - KENWOOD KFC M6930
COMPONENT - MOREL DOTECH 6 MK2
SUB - BAZOOKA 10 " ELW1014
הותקן בsound FX .
חפש גם בשם
kyaba
או
kayaba
אני לא בטוח אבל
kyb זה מין קיצור של קיאבה
Huh?? you mean some dork didn't figure out that the name KYB is read in pronouncing the name of the letter - K. Y. B. ... it's not kyaba or any thing like that
.Moti
.Moti
moti, moti...try again
Deepal S05 MAX MY26 272Hp
   Citroen Berlingo XTR MY17
 1.6
HDi 100Hp Automatic
מוטי לא יפה לכתוב "דורק...", אתה לא תמיד יודע הכל (דוגמא לעיל) אז...
תחשוב לפני התגובה.
שא ברכה.:wink: .
למה דווקא לאלה? יש המון חברות משובחות... בילשטין ...
ואם על הזולים יותר ...מונרו...
:screwy:
Ay ay ay.. this is interesting, never saw that on any of the US packages... what do I know anyways... I was only a dealer for KYB shocks for a year and have seen more KYB packages coming and going like most of the members of this forum combined together, apparently not enough though
.Moti
have seen more KYB packages coming and going like most of the members of this forum combined together,.Moti
Dont be so sure and dont be so boastful, some modesty wont hurt you.
Regards
Itzik N.
 1.6
HDi 100Hp Automatic
Itzik, I'm truly sorry, I didn't mean to come across like a jacka$$, it's just that I have in fact been a dealer for KYB shocks for a years and have seen a bazillion packages coming and going... no hard feelings and I normally am a modest person and this really doesn't have to do anything with it... the writing Kayaba doesn't exist on US packaging as far as I remember, and as much that you know and I know now that you are correct, it might be that I'm not wrong either
:wink: Cheers Itzik, don't be so serious, some things are better taken on the lighter side
.Moti
.Moti
Moti, its okay... i think that the only reason the you can see "kayaba" on those packages is because those are truly Japanese imported merchandise.
There is a high possibility that the US market get the merchandise from the US manufacturing that located in North America.
In this page you can see that KYB is manufacturing also in US - and also in other locations.
Regards
Itzik N.
 1.6
HDi 100Hp Automatic
DAVID, קח בחשבון עלות של כ 440~ שח לבולם (בדוק).
איציק
ואוו , זה הרבה כסף...:(
אבל שוב אני באותה הבעיה , מונרו אני לא ממש רוצה לשים , היו כאלה מורכבים על הרכב עד עכשיו ואני לא הייתי מרוצה מהם בכלל , KONI זה יקר מידי ועכשיו מסתבר שגם KYB זה אותם המחירים פחות או יותר.
איזה עוד פירמות טובות קיימות שלא עולות יותר מידי כסף ?
הבולמים מיועדים לשתי מכוניות , סיטרואן AX ודייהטסו שרייד .
ובכל זאת אם מישהו מכיר משווק של הבולמים האלה אני מאוד ישמח לשמוע עליו .
אגב מוטי ,
בלינק הזה אתה יכול לראות שהשם KAYABA מופיע ממש ליד השם KYB ,
וזה באתר רשמי של היצרן .
http://www.kayabaeurope.com/cgi-bin/kyb/kybdata.pl?next=show_catalog&mode=catalog&maker=Citroenp_space(F)&model=AX&application=10p_spaceE/RE,p_space11p_spaceE/RE,p_space11p_spaceTRE,p_space14p_spaceTRS,p_spacep_space
14p_spaceTZS,p_space14p_spaceD/RD/TRD,p_spaceGT
תודה ,
דוד.
HU - RFX 9210
AMP - SONY XM-222
SPL 500W MONOBLOCK
הותקן בsound FX .
You're pretty much getting what you paid for, unfortunately there are no magic products in the market that are good, reliable and cheap at the same time
.Moti
אז בעצם מה שאתה אומר שזה או הכל או כלום... האמת , הגיוני .
תראה הרכב שלי הוא לצערי לא רכב מהנה יותר מידי לנהיגה אבל הוא עושה את העבודה ואני מתכנן להחזיק אותו לתקופה לא קצרה , האם שווה להשקיע בבולמים טובים באמת (ואם כן איזה מכל הפירמות הכי מתאימה לדעתך ? ) או שפשוט לקנות את הזבל הזול ?
דוד
HU - RFX 9210
AMP - SONY XM-222
SPL 500W MONOBLOCK
הותקן בsound FX .
