dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7000 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
אני צריך עזרה בבחירת מגבר שיקנה בארה"ב בתקופה הקרובה.
תמליצו לי מה מבין המגברים הללו כדאי לקנות? כמו כן אם יש למשהו המלצה על מגבר אחר אז שיתן.
Crunch BMX 4100
BlackMaxx BMX 4100 4-Channel 4x150 Watts Amplifier
  • 4 x 100 into 4 Ohms
  • 4 x 150 into 2 Ohms
  • 2 x 300 into 4 Ohms
  • BlackMaxx High Dissipation Heat Sink for more effective heat dissipation
  • Illuminated BlackMaxx M on top-plate
  • Crunch MOSFET's for clean, reliable, high-speed, high performance output.
  • G-Force Power Supply - PWM power supply instantly delivers maxx current.
  • SEPP (Single Ended Push Pull) A/B Amplifier Operation
  • Bass Boost Circuit for Enhanced Bass Response
  • Versa Cross featuring Hi-Pass and Low-Pass Adjustments
  • High Level Amp Inputs for OEM Receivers without Preamp Outputs
  • Silver RCA Inputs
  • Silver RCA Outputs for Amplifier Daisy Chaining
  • Protection Circuitry guards against; current, short circuit, or thermal overload damage.
  • * Picture shows the BMX4175 which looks the same as this model
Crunch PZi 175.4
1000W 2 / 3 / 4-Channel A/B Class Amplifier
  • RMS @ 4-Ohms: 175W x 4-Ch
  • RMS @ 2-Ohms: 250W x 4-Ch
  • RMS @ 4-Ohms: 500W x 2-Ch
  • Dynamic Music Watts
  • SEPP A/B-Class PZi Amplifier Designs
  • Bridgeable Designs
  • Illuminated, Large New Design Crunch Logo
  • PZi. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
  • 2-Ohm Capable A/B Class
  • Config to 3-Ch R & L and Sub Mode
  • Rugged MOSFET Audio Outputs
  • PZi Amp Protection with System Diagnostics LED's That Protects Against:
    • Current / Amperage Overload
    • Short Circuits
    • Thermal Overload
    • DC Offset
    [*]Hi-Level Speaker Lead Inputs
    [*]Silver Preamp Level RCA Inputs
    [*]Daisy Chain Line Outputs
    [*]Versa Cross™ Sound Shaping Controls:
    • Mono/Stereo Switch
    • HP/LP/Full-Pass Freq. Selections
    • Crossover Frequency Adjustments: 60 Hz to 1.2kHz
    • (30 Hz to 250 Hz Low-Pass)
    [*]Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz
    [*]Input Level Control (0.2 to 5V)
    [*]Oversized Speaker Terminals
Pioneer GM-6200F
600W 4-Channel Bridgeable Amplifier
  • Bridgeable 4-channel capability 4 x 120W or 2 x 300W (Max. Power)
  • Continuous output power @ 4Ohm: 4 x 60W or 2 x 150W (14.4V (20-20kHz/4ohms))
  • Continuous output power @ 2Ohm: 4 x 75W (14.4V (20-20kHz/2ohms))
  • Load impedance capability: 2 — 8Ohm
  • Variable LPF( -12 dB/Oct): 40 - 120 Hz
  • High Voltage Input capability: 200 mV — 6.5 V
  • Type: Bridgeable Power Amplifier
  • Channels: 4
  • Input level/gain control
  • Load impedance capability: 2 - 8 Ohm
  • RCA terminals (input/output)
  • RCA input terminals
  • Speaker Terminals: Screw-type
  • Power / ground terminals: Large screw-type
  • LPF: 80 Hz
  • HPF: 80 Hz
  • High voltage input capability: 400 mV - 6.5 V
  • Maximum Output Power @ 4Ohm: 4 x 120W or 2 x 300W
  • Distortion:
  • S/N ratio: > 95 dB
  • High Voltage Input Capability: 400mV - 6.5V
  • Chassis size (W x H x D): 300 x 361 x 336 mm
  • Unit weight: 3.9 kg
Boss Audio CH650
650W 4 Channel MOSFET Bridgeable Power Amplifier
  • 4 Channel MOSFET Bridgeable Power Amplifier with Remote Subwoofer Level Control
  • Max power, 2ohm: 250W x 4
  • RMS power, 4ohm: 100W x 4
  • Bridged power, 4ohm: 500W x 2
  • Signal-to-noise ratio: 102dB
  • TDH: 0.01%
  • Dimensions: 11-3/4"Wx2-11/16"Hx14-7/8"L
  • Trimode operation
  • Remote subwoofer level control
  • Line and speaker level inputs
  • variable gain control
  • Power and protection LEDs
  • Variable lowpass crossover
  • High pass crossover
  • 0-+18dB variable bass boost
  • MOSFET power supply
Lanzar MXA412
1000 Watt 4 Channel High Power MOSFET Amplifier
  • 4 x 125 Watts RMS at 4 Ohms
  • 4 x 250 Watts Max at 4 Ohms
  • 2 x 500 Watts Max at 4 Ohms Bridged
  • 4 x 200 Watts at 2 Ohms RMS
  • Electronic Crossover Network
  • Variable Phase Shift Control
  • 2 Ohms Stereo Stable
  • Anti-Thump Turn-On
  • Tri-Mode Configurable
  • Soft Turn On/Off
  • High & Low Level Inputs
  • Blue Light Illuminated Crossover Control
  • Power & Protection LED Indicators
  • Advanced Protection Circuitry
  • Bass Boost Remote Control
  • T.H.D: 0.04%
  • S/N Ratio: 90dB
  • Channel Separation: 65dB
  • Frequency Response: 15Hz- 35kHz
  • Dimensions: 10.47"W x 2.46"H x 12"L
Sony XM-SD46X
4 Channel 600W Amplifier
  • 4-channel car amplifier
  • 60 watts RMS x 4 at 4 ohms (75 watts x 4 at 2 ohms)
  • 150 watts RMS x 1 bridged output (rear channels only) at 4 ohms (4-ohm stable in bridged mode)
  • variable high-/low-pass filters (50-300 Hz at 12 dB per octave)
  • bass boost (10 dB at 40 Hz)
  • Tri-way capable (Tri-Way Crossover required)
  • MOSFET power supplies and output stages
  • CEA-2006 compliant
  • preamp- and speaker-level inputs
  • requires 4-gauge power and ground leads
  • 15-7/8"W x 2-1/4"H x 11"D
לא שכחת משו יש עוד מגברים שלא נתת פירוט עליהם...
בקיצור, מה אתה צריך להגביר?(סאב? כמה RMS הוא? קומפננט? כנ"ל)
יהיה יותר קל לעזור....
מנוע V6 בלי להתבייש.
המגברים שנתתי עליהם פרוט הם המגברים שנראו לי והים בטווח המחירים שאני מעוניין להוציא על המגבר.
המגבר יהיה מחובר לקומפוננט מקדימה עדיין לא סגור איזה אבל זה יהיה כנראה מורל פולס/ MB QUART / JBL
השאלה היא איזה קומפטננטים תשים? כמה RMS הם? 80? 100?
תוכל יותר לדעת באיזה מגבר לבחור כדי להתאים פחות או יותר את המגבר...לדעתי חסר לך קצת ידע נסה לצבור קצת מהFAQ אולי תבין יותר וכך יהיה לך יותר קל להחליט בעצמך. :wink:
