מגבלות על צמיגים
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7890 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
סוף סוף קראתי את הכתבה מעניינת חבל על הזמן
הכמות מידע שיש שם ענקית עד כדי כך שקצת איבדתי
חלק .
האם יש מישהו מבין שיכול להמליץ לי בדיוק מה לעשות
ברכב שלי על מנת לשפר את ביצועי הרכב ????
אההה דרך אגב זה CLIO SPORT .
תודה מראש לכל מי שיוכל לעזור .
LIFE IS A GAME
(NFS UNDERGROUND 2)
WWW.TUNINGLINX.COM
WWW.TUNINGWORLD.COM
WWW.CLIOSPORT.NET
- Ram
Follow the article, it has the route to better handling performance, that route starts with the good tires and good alignment, or, if you have the extra money which I assume you do since you're asking about purchasing 17" wheels and tires, you should purchase better wheels and tires, but not 17's
I can help you, but it will be a lot easier if you told me what size is your original wheel - diameter AND WIDTH, and what is the offset, I'll also need the size of the stock tires, and if you could pull the factory alignment specifications from a shop or from the internet, that will be very helpful as well
.Moti
HERE THE STOCK TYRES SIZE
TYRESSize and profile195/50/R15
TELL ME IF U NEED MORE
AND I HAVE THE SUSPENSION SPECS IF U CAN HELP ME WITH THAT TOO
SUSPENSIONFront: Mac Pherson struts with coil springs,
telescopic hydraulic shock absorbers and anti-roll bar.
Rear: Semi-independent, trailing arms linked by a torsion beam, anti-roll bar.
THANK U VERY MUCH
LIFE IS A GAME
(NFS UNDERGROUND 2)
WWW.TUNINGLINX.COM
WWW.TUNINGWORLD.COM
WWW.CLIOSPORT.NET
- Ram
I can obviously read Hebrew, I just can't type, so you can keep writing in Hebrew... back to the questions I had, okay, so I see that your tire size is 195/50R15, but what is the wheel width and offset? also, if you can get the factory alignment settings that would be great
.Moti
