מונובלוק Celestra FA1.6k הספק- 1650 rms באחד אוהם
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4251 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
2200 שח
בה.פ.
Balanced D class" circuit design cancels all THD and IMD distorsions Power at 4 ohm: 1x 500 Wrms (THD 0.1%)
Power at 2 ohm: 1x 1000 Wrms (THD 0.3%)
Power at 1 ohm: 1x 1650 Wrms (THD 1%)
Power with 2 linked amps at 4 ohm : 1x 2000 Wrms
Power with 2 linked amps at 2 ohm : 1x 3300 Wrms
2 independent power supplies
Built-in low pass filter adjustable from 35Hz to 250Hz
Adjustable phase: 0° ~ 180°
Remote level control knob
Power Relay as protection and mute
2 amps link function: Output Master/Input Slave
Massive battery and speakers connectors (0AWG battery);
Heavy duty heatsink design, high cooling thermal capability at full power running;
Fine light gray polished finish.
