XMAX של סאב פיונר 305C
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7949 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
TS-W305C / TS-W125C
T/S PARAMETERS
Dia. 12 in.
Z 4.0 ohm
Re 3.0 ohm
Zmax TBD
fs 32.7 Hz
Qms 15.10
Qes 0.348
Qts 0.340
Vas 1.817 ft3
51.449 Liters
Sd 0.0460 m2
0.495 ft2
BL 15.988 Tm
Cms 1.717x10-4 m/N
Mms 138.20 g
Rms 1.875 Ns/m
Mg. Wt 2,350 g
83 oz
VC dia. 2.25 in.
56 mm
Hvc 1.12 in.
28.4 mm
Hag 0.39 in.
10 mm
Xmax 0.36 in.
9.2 mm
Levc 2.107 mH
Displ. 0.083 ft3
2.36 Liters
SPL 89 dB/W
Power (nom) 400 Watts
Power (max) 800 Watts
RECOMMENDED ENCLOSURES
Sealed - 1.5 ft^3
Ported - 1.65 ft^3 (3" diameter, 6" long)
4th order bandpass - 0.9 ft^3 sealed, 0.9 ft^3 ported (3" diameter, 5" long)
המשתמש עזב את הפורום.
if i have seen farther than other men it is because i have stood on the shoulders of giants
