Quadra-Trac-II - איך זה עובד?
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5327 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
Quadra-Trac II
The Quadra-Trac II 4 x 4 system gives owners the benefit of the NV245 active transfer case and BTCS. The transfer case is the same one used in the Quadra-Drive II system. It takes input from a variety of sensors to determine tire slip at the earliest possible moment and take corrective action. The system also uses Throttle Anticipate – sensing quick movement in throttle from a stop – and it takes steps to maximize traction before tire slippage even occurs.
Torque is transferred to the individual wheels as needed by the BTCS to maintain traction in changing road conditions. When the system senses tire slip, it modulates brake pressure to the slipping wheel, which directs torque to the tires with the best traction. Quadra-Trac II features an electronic shift mechanism for ease-of-use. The transfer case also includes a neutral position for trouble-free towing behind another vehicle.
