dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4318 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
שלום יש לי sx4 2008, רציתי לדעת האם לאחר פירוק המצערת האלקטרונית וניקויה, יש להתחבר למחשב לצורך כיול מחדש ? או שברכב זה אין צורך. תודה.
מתוך ה Service Manual המקורי של סוזוקי:
Description of Electric Throttle Body System Calibration
S6RW0D1101007
ECM calculates controlled opening of the throttle valve on the basis of the completely closed throttle valve position of
the electric throttle body system. The completely closed position data is saved in memory of ECM. However, the
completely closed position of the throttle valve of the electric throttle body system (signal voltage from throttle position
sensor when throttle is completely closed) differs one from the other depending on individual differences of the throttle
valve and throttle position sensor. As such individual differences must be taken into account for controlling the throttle
valve, it is necessary to register the completely closed throttle valve position data in ECM. When such data is
registered in ECM, it is saved in RAM (memory) of ECM and used as the base data for controlling the throttle valve.
This data is cleared, when any of the works described in “Precautions of Electric Throttle Body System Calibration” is
performed.
Also, after replacement of the throttle body and/or APP sensor assembly, the completely closed position data in
memory of ECM must be cleared once and a new one must be registered, or ECM cannot judge the complete closure
position properly.
For the procedure to register such data, refer to “Electric Throttle Body System Calibration in Section 1C”. (After the
completely closed position data is cleared, ECM, for the first time only, opens and closes the throttle valve for about 5
seconds after the ignition switch is turned ON position, for registration of the completely closed throttle valve position.
If the engine is started during this registration process, such symptom as “longer cranking time” or “slow rise of
revolution speed immediately after start-up” may occur. However, turning OFF the ignition switch once and restarting
will set correct registration.)
כן, יש צורך בביצוע כיול לאחר פירוק בית המצערת. למזלך הכיול מתבצע כך:
1) If electric throttle body assembly and/or accelerator
pedal position (APP) sensor assembly are replaced,
perform following steps.
a) Disconnect negative cable at battery for 20
seconds or more for the purpose of clearing
calibration data of closed throttle position from
memory in ECM.
b) Connect negative cable to battery.
2) Keep ignition switch at ON position for 5 seconds or
more without running engine.
איתמר
עמוד 1c-5.
איתמר
האם אתה מסתכל על הספך שבעמוד הראשון כתוב:
suzuki sx4 2008
owner's manual
אני לא מוצא עמוד כזה 1c-5
עריכה אחרונה על ידי s0d
לא, רשמתי service manual, התנ"ך של הרכב, ספרות יצרן טכנית מקורית. 1,600 עמודים.
איתמר
