dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 8048 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
ok.. so i bought the rockford fosgate p4004 and i also bought the kicker c10d (10" 4 ohm) wich will be pushed by two channels of the rockford...
do you think it is a good match?
who is stronger in this situation?
will it be smarter to buy the 12" kicker and try to sell the 10" in israel?
or am i too greedy and the 10" will be enough?
יש רק בעיה אחת הרוקפורד הוא 4*50 ב-4 אום והסאב הוא בגירסת D-4 שני סלילים של 4 אום כלומר אתה צריך להפעיל אותו עם מגבר שיכול לרדת ל-2 אום ,חפש את הסאב בגירסת D-2 כלומר שני סלילים של 2 אום ואז תוכל לחברו לרוקפורד
please
can you or can anybody else explain me in specific details why does the kicker c10d would not work with the rf p4004?
that motherfuckin dominican told mt they will and now you say they won't
those fucking jews own that "uncle steve" place and doesn't know a thing about car audio, tomorow i'm gonna be israeli and stand for my consumer rights
please.. tell me what else i can do about that...
if they would offer me to trade with another model, wich models at the size of 10" to 12" are recommended?
please i need the answers fast because i need to go there tomorow
i'm sorry i'm not mesharsher
please fellas.. it's really important to me.. i want to go to the store today
explain me why this subwoofew won't work with that amplifier
can you use english terms as well?
Okie, listen dude.
This amplifier isn't good for you, because it's 4-ohm stable in bridged mode
and your Subwoofer (Kicker CompVR 10") is DUAL VOICE COIL (DVC) 4 ohms
That's means, you need amplifier that stable at 2 ohms.
You can use the all 4 channels, and wire it in bridged mode, but it will take you all the amplifier channels. (bridged ch1+ch2 for 1 voice coil, and ch3+ch4 for the second voice coil - though it's not recommended.)
You wanted to wire this amplifer to the sub, and 2 more speakers?
as you know, in USA you can return the item that you were bought, and get ALL your money back.
"about 12", it's 10$ difference, but more useful than 10
Enjoy. :wink:
Oren.
Oren.
ok, thanks for the quick answer
i'm not really sure about the refund rules over here.. it seems to me that these rules varies between each retailer
but i'll try my luck
thanks
and another thing... the subwoofer got only two connections, is there any chance that DVC's need to have 4 connections?
or am i just trippin'?
guys.. sorry to bother you but i need to be sure that i have the DVC model
my model's name says is C10d, on the back of it written "4 ohm" (no mention for DVC(
it look exactly like the model right here:
http://www.carreview.com/Subwoofers/Kicker/PRD_50543_1808crx.aspx
(here they also not saying anything about DVC)
at the same website, one product below i found this:
http://www.carreview.com/Subwoofers/Kicker/PRD_288006_1808crx.aspx
this subwoofer does not lookes like my subwoofer and it's model is slightly different (c10vr, mine is c10d)
in this model they do mention the DVC thing...
how can i know wether my model is DVC or not???
קודם כל הסאב לא DVC כי אמרת שיש רק 2 חיבורים וכנראה התכוונת לפלוס ומינוס אז זה רק חיבור אחד.
הראשון זה לא 2 סלילים כי כתוב שבוא יכול להיות או 4 אום או 8 אום. אז זה לא מסתדר כי כדי להגיע ל8 אום בDVC צריך 2 סלילים של 4 אום ואם יש 2 סלילים של 4 אז האפשרות ה2 של חיבור מקבילי תיתן 2 אום ולא 4. אז אני חושב שהוא פשוט בא ב2 דגמים ואצלך הוא 4 אןם. גם בדרך כלל כותבים אם הוא DVC.
i've probably got the upper one, according to all the details ant according to the picture as well..
does that mean that i got the non-DVC than?
so would the non-DVC fit my amplifier?
חיובי (אני שוב מדגיש, אינני יודע אם זה סליל יחיד או כפול, כך שאני לא יכול לבסס את תשובתי באופן חד משמעי).
תתחדש.
תתחדש.
thanks...
just another thing..
you thing the amp would push the 12" good as well?
thanks...
כן.
גם עופר (הידוע בכינויו KICKER) היה בזמנו עם סאב "12 של קיקר קומפ שמקבל 200W RMS. ולטעתנו, עבד יפה, וללא שום בעיה.
וגם יש האומרים שרוקפורד תמיד מפחיתים את ההספקים שלהם, אז תוסיף לזה עוד כמה אחוזים בודדים. :wink:
אורן.
