dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4858 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
מפרסם עבור חבר. מליר 200 במקום 600.
NGK ILFR6B Iridium Spark Plugs - 4 Pack - 2004-2007 Subaru WRX STi
Application: 2004-2007 Subaru Impreza WRX STi
Heat Range: 6 (Stock)
Thread Size: 14mm
Hex Size: 5/8" (16mm)
Reach: 26.5mm (1.04")
Seat Type: Gasket
Gap: .032" (0.8mm)
NGK's Laser Iridium Spark Plugs Provide Superior Ignitability and Long Service Life.
Fine Wire Iridium Tipped Center Electrode and Fine Wire Platinum Tipped Ground Electrode Ensures Slow Wear Rate Providing Stable Idle, Superior Anti Fouling, Improved Fuel Efficiency and Lower Emissions.
Trivalent Metal Plating Provides Superior Anti-Corrosion and Anti-Seizing Properties
Corrugated Ribs Prevent Flashover
Pure Alumina Silicate Ceramic Insulator, Provides Superior Strength and Better Heat Transfer
Copper Core Aids in Heat Removal
Triple Seals Prevent Leakage
Please Note:
1. Iridium plugs are able to use larger gap setting with less voltage. Some customers choose to regap these plugs to correct misfiring or tune for optimal spark -- do so at your own risk -- slide-type plug gapper will damage the fragile iridium tip.
2. price is for a set of 4 spark plugs.
Peugeot 208 GTI 2016
