מפת פיוזים ל205
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6334 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
General
System type .................................... 12-volt negative earth
Fuses (early models)
No Circuit protected Rating (amp)
1 Reverse light, cooling fan relay, tachometer (GTI) ............ 10
2 Accessories, indicators, fuel gauge, warning lights,
heater blower motor ........................................... 25
3 Ignition switch, wash/wipe system, stop-lights,
tachometer (non-GTI option), radio, heated rear window,
electric window relay (option),
clock illumination (GTI) ...................................... 25
4 Central door locking (option) ................................. 10
5 Cooling fan ................................................... 25
6 Hazard warning switch ......................................... 10
7 Spare ......................................................... -
8 Cigarette lighter, clock, interior lights,
glovebox illumination, radio .................................. 20
9 Electric front windows ........................................ 25
10 Heated rear window, horns ..................................... 20
11 Rear fog light ................................................ 5
12 Side/tail lights/warning light,
instrument panel illumination, number plate lights ............ 5
13 (In-line) fuel pump (GTI) ..................................... 25
Fuses (1986 to 1988 GTI and CTI models)
1 Reversing lights, tachometer .................................. 10
2 Direction indicators, heater blower motor, oil pressure gauge,
oil temperature gauge, heated seats, fuel gauge,
coolant temperature gauge, low battery charge warning,
oil pressure warning, brake system warning,
coolant temperature warning, low coolant level warning ........ 25
3 Windscreen wiper/washer, stop-lights, headlight washer,
radio, accessories ............................................ 25
4 Spare ......................................................... -
5 Hazard warning ................................................ 10
6 Spare ......................................................... -
7 Cigarette lighter, clock, interior lights, boot light,
central door locking, radio ................................... 25
8 Horns ......................................................... 25
9 Electrically-operated windows ................................. 20
10 Rear foglight ................................................. 5
11 Tail light (RH), number plate light ........................... 5
12 Tail light (LH) ............................................... 5
13 Instrument panel illumination, side lights .................... 5
14 Fuel pump ..................................................... 15
Fuses (1988 to 1989 models, except GTI and CTI)
1 Reversing lights .............................................. 10
ignition warning light ........................................ 25
3 Fuel gauge, stop-lights, front and rear wash/wipe,
tachometer, headlight wash, radio, storage tray light,
warning lights (coolant temperature, oil pressure,
coolant level, handbrake, choke) .............................. 25
8 Horns, heated rear window ..................................... 25
10 Rear fog light ................................................ 5
11 Tail lights, number plate light ............................... 5
12 Spare ......................................................... -
Fuses (1988 to 1989 GTI and CTI models)
3 Front and rear wash/wipe, stop-lights, headlight washer,
radio, accessories, storage tray light, map reading light ..... 25
central door locking, radio ................................... 20
11 Tail light, number plate light ................................ 5
12 Spare ......................................................... 5
Fuses (1989 to 1991 - all models)
1 Reversing lights, tachometer, fuel gauge, warning lights
(low battery charge, coolant temperature, oil pressure,
low coolant level, brake system, choke) ...................... 10
2 Direction indicators, gauges (fuel, oil temperature,
coolant temperature, oil pressure), heater blower motor,
warning lights (low battery charge, coolant temperature,
oil pressure, low coolant level, brake system, choke) ......... 25
3 Map reading light, stop-lights, windscreen and tailgate
wash/wipe, tachometer, radio, glovebox light, electric windows,
heated rear window ............................................ 25
4 Driving lights ................................................ 15
5 Hazard warning lights ......................................... 10
7 Cigarette lighter, clock, interior lights, luggage compartment
light, central locking, radio, power feed to tow bar .......... 25
8 Horn, heated rear window ...................................... 25
9 Electric windows .............................................. 20
11 Tail lights, number plate lights .............................. 5
14 Electric fuel pump ............................................ 15
Fuses (1991 models onward)
oil pressure, low coolant level, brake system, choke, ABS) .... 25
tailgate wash/wipe, tachometer, radio, glovebox light,
7 Clock, interior lights, luggage compartment light,
central locking, radio, power feed to tow bar ................. 25
8 Horn, heated rear window, cigarette lighter ................... 30
10 Rear fog lights ............................................... 5
11 Tail lights ................................................... 5
Fuses in engine compartment
ABS .............................................................. 30
Power supply to ABS electronic control unit ...................... 15
Cooling fan ...................................................... 30
Oxygen sensor .................................................... 10
Bulbs Wattage
Headlights:
Non-GTI ....................................................... 45/40
GTI ....................................................... H4 (60/55)
Front parking lights ............................................ 5
Direction indicator lights ...................................... 21
Front driving light (GTI) ................................... H3 (55)
Tail/stop-lights ............................................... 5/21
Reverse light ................................................... 21
Rear fog lights ................................................. 21
Interior light .................................................. 5
Number plate lights ............................................. 5
