dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 8215 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
כך כמה דברים שידידך RC כתב בנושא:
guys------the amp gets hot according to the power it puts out------
the power it outputs is directily related to how loud the speakers are and THE VOLTAGE OF THE DRIVING SOURCE HAS NOTHING TO DO WITH THE TEMP OF THE AMP--------if it seems so its just in your head...........RC
with a line driver the amp does run hotter-----lets do the math-------the voltage input to the amp with a 8 volt signal and a typical input pot of 20Kohm will produce .0032 watts of disipation across the pot------and with a 2 volt signal it will produce only .0002 watts------thats an increase of nearly thirty thousanths of a watt!!!!!!-----and if we are talking about a two channel amp the increase would be doubled!!!!!!and if it was a four channel amp the dissipation would be increased to nearly a hundredth of a watt---------imagine how much hotter a typical thousand watt amp is gonna get with an increased dissipation of an additional 1/100 of a watt--------see why i wear thin with this-----and the worst part is that i have to prove everything because idiots disagree with me.............RC
full volume can be reached with most any amp with as little as a half volt but it might require a gain increase on the amp to do it-----as long as this increase doesn't bring noise there is no need for a line driver.........RC
it is simply amazing how much confusion the elementary subject of signal voltage seems to create---------it ONLY changes TWO things and NOTHING else-------the gains on the amp probably need to be turned lower and there MIGHT be a reduction in noise PICKED up in the interconnect--------nothing else changes------the volume does not change-------the power produced does not change--------the electrical requirements do not change------the amp temperature does not change-------the sound quality does not change unless the extra voltage helps with noise immunity------nothing is different-------it is a very simple issue and is given way too much attention...........RC
זה אולי יכול לעזור במניעת רעשים (עם דגש על אולי) אבל בטח לא בעליה מ4V ל8V ובטח לא אם יש לך ציוד נורמלי שמותקן טוב.
נכון... בגלל זה אמרתי שבאופן כללי זה דבר טוב שיהיה.
ובשום אופן שזה לא יהיה אחד הגורמים העיקריים שנסתמך עליהם בקנייה של רדיו.
אנחנו רוצים כמה שיותר תכונות טובות, וולטאז' גבוה והתנגדות נמוכה הם אחד מהם.
לאלפיין יש preouts עם התנגדות של 10,000 אוהם, וגם ל Nak-700 שנחשב לרדיודיסק יקר.
הרבה מבקרים התפלאו לערך הגבוה, אבל הם עובדים מצויין..
If I have seen further than other men it is because I have stood on the shoulders of giants.
אני רק אומר שזה תכונה שעדיף שתיהיה...
אף תכונה של רדיו לא יכולה להבטיח לך דבר, אבל אנחנו רוצים כמה שיותר תכונות טובות.
וכשאני ישקיע סכום כסף על רדיו, אני יצפה לpreouts יציבים.
