dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4530 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
אהלן,
מישהו יכול להסביר לי את ההבדל שבין סוגי המגבות
מיקרו, אובר, באפינג, וואפל ומה היעוד של כל אחת מהן ?
אגב, אני ספציפית מחפש מגבות למשטחים עדינים ( כיירים.... כן כן, כיירים גרמניות ששימוש בחומר קשה עושה אותם לכיירים צבאיות...
:wink:)
בברכה,
רועי.
קצת מידע..
http://www.microfiberwholesale.com/How-Microfiber-Works.html
http://www.microfiberwholesale.com/Washing-Microfiber.html
http://www.microfiberwholesale.com/Using-Microfiber-Cleaning-Cloths.html
http://www.microfiberwholesale.com/determining-the-quality-of-a-microfiber-towel.html
עוד קצת..
What is microfiber? Microfiber is a fiber with less than 1 denier per filament. The Denier is a measure of linear density and is often used to describe the size of a fiber or a filament (9000 meters of a one-denier fiber weighs only one gram). Fibers are combined to form yarns. Yarns are knitted or woven in a variety of constructions. While many microfibers are made of polyester, they can also be composed of Polyamide (nylon) or other polymers. What is microfiber made of? Most microfiber products are made of 80% Polyester, 20% Polyamide or 70% Polyester, 30% Polyamide.
How is microfiber manufactured? Microfiber products used for consumer cleaning are generally constructed from split conjugated fibers of polyester and Polyamide. When a high-quality microfiber is combined with the right knitting/weaving process, it creates an extremely effective cleaning material.
What are the benefits of microfiber? Thoroughly removes dust, allergens, and bacteria Antibacterial - Proven wipe surface 99% bacteria free without using chemicals and without cross-contamination. Highly absorbent - Microfiber can hold up to 7 times its weight in liquids. Limitless utility - Household chores, auto detailing, and even personal use. Non-abrasive - Safe to use on stainless steel, crystal, cars. Effortless cleaning - tiny microfibers get into cracks and crevices to get those hard to reach spots. Multifunctional - Use wet for tough cleaning jobs or dry for dusting. Dries and polishes to a streak-free and lint-free finish.
How durable is microfiber? Microfiber is a very durable material and can be washed hundreds of times. A cotton towel appearance and functionality will be visibly reduced after 20 washes or so, microfiber can sustain 300 to 500 washes with very limited effect on the product.
How to wash microfiber? Hand or machine wash with mild detergent. Wash and dry with like, non linting materials. To maintain your microfiber original properties, do not use chlorine bleach, fabric softeners or dryer sheets. Tumble dry low.
How does microfiber work? Unlike cotton which pushes the dirt in front of the cloth, Microfiber is capable of grasping the dirt in between its filaments and keeps it there until you thoroughly shake the cloth or rinse it.
What is GSM? GSM or Grams per Square Meter is a unit of density of the cloth. Typically the higher the number, the better the quality. Some applications require a higher GSM than others.
What is the difference between Microfiber made in China or Microfiber made in Korea? Answer is Quality!!! For example: 100% of the Microfiber factories in Korea use machines costing 1 Million. 90% of the Microfiber factories in China use machines costing $100K. The difference is in the processing and finished work of the cloth. It's like night and day difference.
אם יש לך שאלות נוספות תשאל.
עריכה אחרונה על ידי Kenworth
:wink: if it's not clean enough :arrow: add some elbow grease
**Warning, this post may contain sarcasm ... it's your decision to get upset about it**
בבקשה לא לשלוח לי ה.פ עם שאלות שרלוונטיות לפורום דיטיילינג :nono:
קצת מידע..
עוד קצת..
Kenworth,
מעניין מהיכן הציטוט.... מבלי להיכנס לאמיתות העובדות ( מה שנראה לי יומרני להצהיר על הקוראנים בתור 100% והסינים ב - 90% )
הרי שאת מגבות הכימיכל גייס שרכשתי מארה"ב ( אחד ולפעמים שניים מכל סוג ואל תשאל אותי למה...) הרי שעל כולם רשום made in china.... ולא נראה לי שהם נופלים מהאיכות שמציע הקוראני מאייבי...
דווקא לי נראה..
ואם אתה מחפש מבדק אמין תבצע כמות מרובה של כביסות ותראה איך כל אחת מתנהגת לאחר X כביסות, או לחילופין תן לשתי המגבות "בראש" - טפל בהן באמצעים קיצוניים ובדוק מי מתפרקת ראשונה (שטיפות חמות עם 60 מעלות ומעלה, כמות גדולה של סיבובים במכונה, ייבוש בשמש וכו', החדרה בכוח של כמות רבה של מזהימים (לכלוך, אבקת כביסה וכו'), עבודה מרובה עם מוצרים גסים כמו APC בדילולים קשים )
אני מסכים עמך שזו הצהרה מאוד יומרנית ואולי פה ושם המציאות שונה אבל נתקלתי בהצהרה הזו בהרבה מאוד מקומות ולעניות דעתי יש דברים בגו.
אכן מכונות האריגה בסין זולות יותר ועובדות בשיטת אריגה אחרת מזו שעושים בקוריאה. זה עובדתי ולא מעשייה. תכנס לפורומים רציניים בעולם שם דנים בבדים ולאו דווקא בבדים עבור תעשיית הדיטיילינג ותיווכח שהרבה אנשים מודעים לאיכות הסינית וזה לא דבר חדש.
כמובן שיש הרבה גורמים שישפיעו על התוצר הסופי כמו:
  • סוג התערובת- 80/20 או 70/30 או כל משחק אחר
  • ייצור סיני או קוריאני
  • יש מצב מאוד נפוץ בו האריג הינו קוריאני והתפירה הסופית נעשית בסין לשם חסכון בעליות
  • כמה ידיים המוצר החליף לפני שהגיע ללקוח הסופיי
  • וכמובן התווית הלוהטת שמתנוססת עליו בגאווה והיא תתן את חותמת המחיר האחרונה
  • סביר להניח שיש עוד משתנים
מגבות סיניות אני יכול לקנות גם בalibabab או בaliexpress באיכות שלא יורדת מזו של חברות הדיטיילינג שכן לרוב הo קונים את מוצריהם מאותם המפעלים הסיניים. כשאתה רוכש מגבת ממותגת בX כסף אתה בהכרח משלם על המסביב ולא על המוצר (שיווק וכו'). ואגב זה בסדר.. אני לא נגד קנייה שכזו כל עוד מדובר עבורי במחיר הנכון ובצורך כלשהו במוצר. אם אנשים קונים סמארטפונים ב3000₪ אז מגבת ב50₪ לא תהרוג אותנו..
לגבי הציטוט- הוא נלקח מהאתר של rosco microfiber, יבואן גדול בארה"ב שמייבא מגבות איכותיות ומוכר בכמויות גדולות.
אתה יכול לחפש ברשת מידע אודות ההבדלים בין האריג הסיני לזה הקוריאני ולהסיק את המסקנות שלך ואם יהיה לי מידע חדש לשפוך אני אשמח לשמוע פה או בהודעה פרטית.
עריכה: מצרף לך 2 דוגמאות שאני יודע בוודאות שנמכרות בעולם בתור מותג דיטיילינג (אני מכיר לפחות אחד כזה ב100%), שים לב למחיר עבור הכמות ותוסיף לזה את העובדה שהמוכר הנ"ל הוא לא היצרן בכלל והוא גם מרוויח דמי תיווך.
מגבת ייבוש מעולה בתצורת וואפל 380-400 GSM |לינק|
מגבת נפוחה כ900 GSM |לינק|
מיוצרות בקוריאה.
לא התלהבתי מהאחרונות שקניתי מהקוריאני.עשויות טוב,מגע רך,תפירה טובה
ניגוב? לא משהו (לא מחליקות מעל הצבע -נתקעות) לעומת מטליות של CG למשל. (אפילו האחרונה של מוטורס עדיפה)
http://www.vixdetailing.co.il/l-Mothers-Ultra-Soft-Quick-Detail-Towel.html
"אם יהיה לי מידע חדש..."
התכוונתי אם יהיה לך..
עופר על איזו מגבת אתה מדבר?
תן לינק.
מבחינת הקוריאני זה דווקא מזכיר את איכות הניגוב של CG (מאוד דומים)
http://www.ebay.com/itm/4pcs-Microfiber-Super-Plush-Detailing-Polishing-Buffing-Towel-Cloth-Korea-/321133660329?vxp=mtr&hash=item4ac50ec8a9
http://www.vixdetailing.co.il/Chemical-Guys-Elite-Gold-Microfiber-1.html
אזמין בעתיד לניסיון.
כמו בכל תחום גם בתחום הזה יש מקורות זהים לייצור מטליות
רק הדבקת תווית של חברה ידועה מעלה את ערך המוצר גם אם הוא זהה באיכותו/הרכבו ל"זול"
לכן התנסות ובדיקה כל מוצר לגופו ולאו דווקא למחירו חשובה.
רציתי לרכוש מ WIX שבוע שעבר מטליות לחלונות מסוג כזה W http://www.ebay.com/itm/3pcs-Microfiber-tricot-glass-window-
לא מופיע באתר שלהם.אחרי התלבטות החלטתי לא לרכוש אותם -נראה לי דומה מידי למפיות אוכל שיש אצלי בבית... וגם לא בטוח שזה מנקה טוב ללא שאריות. עדיין לא מצליח להגיע לחלון נקי כאלו אין חלון במבחן הראש. (כנראה שהזנחה של שנים יצרו שכבות שומנים שמתעקשים לרדת)
למי שפחות חשוב תוויות.
בסופר דיל יש מוצרים עם הלגו שלהם שזה בעצם מיוצר בסונו וכד' באותה רמת איכות רק בלי התווית שלהם.
עריכה אחרונה על ידי yogev20
אמרת שהיא לא מתאימה לניגוב? התכוונת לניגוב סופי? כאילו למטרת ייבוש?
אני מכיר היטב את המגבת הזו והיא אכן גרועה בתור מגבת ייבוש, אפילו מאוד מאוד גרועה, העניין הוא שהיא לא מיועדת למטרה הזו וזה מאוד הגיוני שהיא לא תיהיה מוצלחת במשימת הייבוש.
היא מיועדת בעיקר ל -
QD drying
Wax & sealnat removal
final buffing towel
ואני אוסיף ואגיד שהיא מוצלחת עבור ניקיון כללי, פנים הרכב וכו'.
מתאימה להמון משימות... אבל היא לא מתאימה לשימוש כמגבת ייבוש.
אם התכוונת לניגוב בקטע של ניגוב ווקס או ניקוב QD אז זה קצת מוזר.. כי שם היא דווקא מוצלחת לדעתי.
המגבות tricot שמיועדות לניקוי חלונות הן פשוט מעולות (עבורי) ומנקות היטב ללא השארת סימנים, זה לא מרגיש כמו מפית והן מאוד עמידות וחזקות.
אבל אני מנקה בעזרתן רק לאחר שהרכב עבר שטיפה והחלון ברובו נקי ואז בעזרת המגבת הזו אני עושה פיניש עם חומר מעולה לחלונות.
ייתכן שכאשר הרכב מטונף ורוצים לעבור על החלון המגבת הזו לא תהה כלכך מועילה.
כן כוונתי לניגוב סופי באפינג. ניסיתי גם QD עדיין חייבים מטלית נוספת לפיניש.
דווקא מוטורס מצוינת.
לפנים הרכב אני נוהג להשתמש בפשוטות. לעולם אני לא מנקה חלונות שהרכב מטונף
תמיד אחרי ניקוי יסודי עובר על החלונות.
