dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 7031 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
בגלל מגבלות מקום אני חייב סאב דק (shallow sub)
לאחר חיפוש ברשת מצאתי כמה אפשרויות
אשמח אם תוכלו לתת לי חוות דעת על הסאבים למטה וכן על אפשרויות אחרות .
תודה
1. KICKER CVT10 4 OHM 10" SHALLOW SUBWOOFER
Features: Kicker Comp VT Series
800 watts total output power
400w RMS
Impedance: Single Voice Coil 4 Ohm
Extremely Shallow Mounting Depth
Injection-Molded Polypropylene Woofer Cone
Ribbed Santoprene Rubber Surround
Marine-Ready: powder coated, weather resistant basket, and stainless steel hardware
Spring-Loaded Nickel Plated Speaker Terminals
Resonance Frequency : 32.7Hz
Frequency Response : 25- 350 Hz
Sensitivity : 85.5 dB
Sealed Enclosure : 0.8 - 3.0 cu.ft.
Vented Enclosure : 1.25 - 1.75 cu.ft.
Mounting Depth : 4-3/16"
Hole Cutout Diameter : 9-1/8"
2.POWER ACOUSTIK STW-10 10" SHALLOW DEPTH SUBWOOFER
Specifications:
800 Watts Power Handling
400 Watts RMS
100 oz. Magnet
2" BASV/Kapton Hybrid 18 AWG Voice Coil
SPL 88dB
Fs: 35Hz
Vas: 0.08 cu.ft.
Qms: 8.133
Qes: 0.4778
Qts: 0.458
Xmax: 0.3"
Sealed Box: 0.7 cu..Ft.
Ported Box: 1 cu..Ft.
Tuning: 38Hz
Port Size: 3"(dia)x10"(length)
# of Ports:
3.CLARIONPFW1051 Shallow 10" Subwoofer
  • Single 4 Ohmn
  • Heat resistant voice coils
  • Kevlar/paper composite cone design
  • Polyporopylene electrolytic spun aluminum coated dust cap
  • Hyperexteded vented pole piece
  • Co polymer composite high excursion surround
  • Dual strontium ferrite magnet motor
  • Dual gold plated block terminals
  • Peak Power Handling600Watts RMS Power Range300Watts Impedance ( Ohms )4 Ohm Free-AirYes Dual Voice CoilNo Cone MaterialKevlar/paper Surround MaterialCo-polymer Top Mount Depth3"
4.P3SD410 10" Punch P3 4-Ohm DVC Shallow Subwoofer
Size10"Impedance4-Ohm x 2Power Handling300 Watts RMS
600 Watts MaxSensitivity83 dBMotor Size46 oz.Voice Coil Diameter2.5" 4-Layer
(6.35 cm)Speaker ConnectorDual 10 AWG compressionMounting Depth3.50"
(8.89 cm)Rec. Sealed Enclosure0.50 cu. ft. (16.42 liters)
Range: 0.40 cu. ft. - 1.0 cu. ft.
Range: (11.33 liters - 28.32 liters)Rec. Vented Enclosure0.75 cu. ft. (21.24 liters)Tuning Frequency (vented)46 Hz
Port: (1) 3" diam. x 12" long
Port: (1) 7.62 cm x 30.48 cm
אני לא מכיר את האלמנטים שאמרת.
אבל אני שמעתי אלמנט דק של חברת ארפקוייק. SWS. והוא היה מצויין!
תריץ חיפוש בגוגל.
גלגלצ: דיווחי תנועה ביציאה ממצרים. עומס תנועה ענקי ממחלף סיני עד מחלף ים סוף, משה תיזמן 40 שנה. תודה לך משה.
מודעת מכירה ................ פרויקט איטום על הרכב שלי
