Crescendo FT1 + Crescendo Pwx8
wowohw
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 2873 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
2 זוגות של Crescendo Pwx8 4ohm חדשים בקרטון לא שומשו, מדובר על הצורה החדשה.
PWX 8" Pro Audio Midrange Speaker
The PWX8 is our extremely popular pro audio inspired 8" midwoofer. Designed to sound extremely clear even when cranked to higher volume and SPL.
Lightwieght carbon/fiberglass composite cone, mated to a kapton former and edgewound copper 2" coil.
As loud as many pro audio midwoofers out there, yet the PWX excels most of them in terms of clarity and sound quality.
More midbass potential than your typical pro audio midwoofer
100% weatherproof/waterproof front end cone/dustcap/surround assembly, meaning as long as the rear of the speaker is sealed off in a proper enclosure, they are certified for heavy marine/outdoor performance without the softparts deteriorating for years to come.
The PWX series is entirely marine grade, ready to be installed on any boat, ATV or even swamp buggy!
Rated 200w RMS
Recommended power range per speaker: 75rms-300rms
Usable Freq response: 76-5100hz @ 200w
Sold individually
Include pan head mounting screws (as of 10/17/13)
Overall Diameter: 8 ¼”
Mounting Depth: 3 11/16”
Hole Cutout: 7 1/4”
Flange Width: 1/2”
Flushmount Trim Height: 3/8”
2 זוגות של סופר טוויטרים crescendo FT1 זוג אחד הוא של 8 אוהם והזוג השני של 4 אוהם, כן משומשים קלות בצבע שחור.
The Black anodized version of our popular Crescendo FT1 Supertweeters. They sport a semi gloss black anodized finish.
The FT1 supertweeter is the result of months of development, with the goal to have outstanding sonic accuracy and output.
A main concern that many people face with standard supertweeters is finding the proper location in their car to easily fit them without heavy modifications. This is hard to do with almost all of them, since they are quite large and as such, lessening the size was big priority when we started planning out this new tweeter.
The FT1 is available in 4 ohm and 8 ohm configurations. 8 ohm model is slightly more efficient per watt.
The end result:
Spun and CNC aluminum construction, chambered Neodymium motor with integrated heatsink fins cast and milled into the motor housing.
Ultra-light Titanium Diaphragm for minimal breakup at extremely high SPL is driven by a 90% Aluminum/10% copper CAW voice coil.
Exponential horn is controlled and designed for full response along a 44 ° dispersion pattern.
The Faceplate, Mounting Flange and Horn assembly is sculpted for minimal acoustic diffraction and with aesthetics in mind.
Usable frequency response: 4800hz-28khz
Ideal highpass crossover point: 5000 -6300hz
Power rating: 80watts RMS each
Sold INDIVIDUALLY
Installation Dimensions
Mounting hole cutout: 2.5"
Mounting depth: 1.9"
Overall face diameter: 3.1"
Flushmount trim depth: 1/4"
0523 חמש 2 2 שש 9 אפס
ברק.
במידה ולא עונה נא לשלוח הודעת וואטסאפ.
נמצא במרכז ומדיי פעם מגיע לאזור הקריות
Amp1: Crescendo 2000.4 Amp2: Zapco ST-2X Mono: Soundqubed 7k DSP: Steg 6TO8 HU:Pioneer X8750BT
Tweeters: Crescendo STS-1 Midbass: Crescendo PWX8 X2
Subwoofer: FI Team4 15" @0.5ohm ALT: JS Alt's 300A
