SUNDOWN Sax-100.4
Jeka.E
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4390 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
למכירה במצב מצוין , היה בשימוש מועט פורק מהרכב ביום שבת.
[TABLE=width: 72%, align: center]
[TR]
[TD=width: 64%]Rated power output[/TD]
[TD=width: 36%][/TD]
[/TR]
[TR]
[TD]----RMS power, 4 ohm stereo
[/TD]
[TD]100W x 4CH[/TD]
[/TR]
[TR]
[TD]----RMS power, 2 ohm stereo
[/TD]
[TD]160W x 4CH[/TD]
[/TR]
[TR]
[TD]----RMS power, 4 ohm bridged
[/TD]
[TD]320W x 2CH[/TD]
[/TR]
[TR]
[TD]Signal to Noise Ratio[/TD]
[TD]>90dB[/TD]
[/TR]
[TR]
[TD]Low pass frequency crossover
[/TD]
[TD]50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
[/TD]
[/TR]
[TR]
[TD]High Pass Crossover
[/TD]
50Hz~5kHz (CH3&4)
[/TD]
[/TR]
[TR]
[TD]Variable Subsonic Filter[/TD]
[TD]10Hz to 500Hz[/TD]
[/TR]
[TR]
[TD]Frequency Response[/TD]
[TD]10Hz ~ 40KHz (+/-1dB)[/TD]
[/TR]
[TR]
[TD]Bass Boost[/TD]
[TD]0~18dB[/TD]
[/TR]
[TR]
[TD]Variable Bass-Boost Frequency Control[/TD]
[TD]35Hz to 120Hz[/TD]
[/TR]
[TR]
[TD]THD@RMS Watts[/TD]
[TD]
[/TR]
[TR]
[TD]Channel Separation[/TD]
[TD]75dB[/TD]
[/TR]
[TR]
[TD]Fuse Rating[/TD]
[TD]30A x 3[/TD]
[/TR]
[TR]
[TD]Input Sensitivity[/TD]
[TD]Variable 200mV~6V (+/- 5%)[/TD]
[/TR]
[TR]
[TD]Dimensions[/TD]
[TD]252(W) x 58(H) x 480(L)mm
[/TD]
[/TR]
[/TABLE]
1400 ש"ח.
0544941870 ג'קה.
2017 Type R
