מספר רכיבים למכירה
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5168 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
מגבר 4 ערוצים Hifonics ZXi 8408
Zeus ZXi Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 110 watts x 4 chan.
2 ohms: 220 watts x 4 chan.
Bridged, 4 ohms: 440 watts x 2 chan.
Pulse width modulated (PWM) MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power and protection indicators
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Variable input control
Bridgeable operation
Soft turn-on circuitry
Preamp RCA outputs
DC, short, thermal, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (10-150 Hz, 24 dB/octave)
Variable low-pass filter (30-150 Hz, 24 dB/octave)
Frequency response: 10-30000 Hz
Dimensions: 15.75"L x 9.45"W x 2.4"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
מחיר- 800 ש"ח.
מגבר 4 ערוצים Rockford R3004
Prime Series 4-Channel Class A/B Car Amplifier
RMS Power Rating:
4 ohms: 50 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged, 4 ohms: 150 watts x 2 chan.
MOSFET power supply and output stage
LED power and protect indicators
Bass Boost/EQ details: selectable bass boost (0, 6, 12 dB at 45Hz)
4/3/2 channel operation
2-Way System Protection circuitry (overload and speaker short protection)
Adjustable gain from 150mV to 8V
Heavy duty extruded aluminum alloy convection heat sink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (80 Hz)
Variable low-pass filter (50-250 Hz, 12 dB/octave Butterworth)
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
Dimensions: 17.09"L x 7.67"W x 2.40"H
8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
מחיר- 400 ש"ח.
סט קומפוננט מורל הייבריד אוביישן 6.5" עם הקרוס הגדול (כולל חיבור BI-WIRE) וטוויטר משודרג ל MT23.
http://morelhifi.com/products/mob_2way_hybrid.html
http://morelhifi.com/products/mob_components_tweeters_mt23.html
מחיר- 800 ש"ח.
יחידת ראש- Alpine 9830- מכשיר בעל איכות מקור גבוהה מאוד:
motorized, detachable fold-down face
plays MP3 and WMA files
plays audio CDs, CD-Rs and CD-RWs
MaxTune SQ tuner
12 FM/6 AM presets
Bass Engine Plus (4-band parametric EQ, 4-channel digital time alignment , a 3-position crossover, subwoofer level and phase control)
MediaXpander
source tone memory
XM and SIRIUS Satellite Radio controls
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
4-volt front, rear and subwoofer preamp outputs
MOSFET internal amp
clock
wireless remote
18 watts RMS/50 peak x 4 channels, CEA-2006 compliant
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
מחיר 500 ש"ח.
טלפון- 050-8786669.
ישראל.
Pioneer P90RS | Celestra RA | Seas Lotus Reference
הקפצה!
נוסף ר"ד פיוניר DEH- P4600MP:
detachable, fold-down face
blue and white display
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA files)
displays MP3 and WMA titles (up to 16 characters)
Supertuner IIID
18 FM/6 AM presets
Easy EQ — five preset EQ curves with 3-band parametric adjustment
Front Image Enhancer — removes high and midrange frequencies from rear speakers
loudness
source level adjustment
MOSFET50 internal amp
XM radio-ready (XM Radio subscription, tuner, antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
CD changer controls
front and rear preamp outputs
wireless remote
clock
22 watts RMS/50 peak x 4 channels
CD signal-to-noise ratio 94 dB
FM sensitivity 8 dBf
מחיר: 200 ש"ח.
טלפון- 050-8786669.
ישראל.
ההייפוניקס נמכר.
ההייבריד וה MT23 נמכרו.
נוסף למכירה:
קלריון DXZ786- מכשיר במצב מעולה, כולל כל האביזרים הנלווים.
שולט אקטיבי, קרוס 3 חלקים, טיים קורקשיין, 3 יציאות של 6 וולט, אקולייזר פרמטרי, USB ועוד.
מחיר: 800 ש"ח.
טלפון- 050-8786669.
ישראל.
