dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 5787 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
Signal - Inlet manifold pressure sensor P0106 - P0107 - P0108 - P0105
Signal - Air temperature sensor P0112 - P0113 - P0110
Signal - Engine coolant temperature sensor P0116 - P0117 - P0118 - P0115
Butterfly position sensor - 1 signal P0122 - P0123 - P0120
Richness adjustment P0130 - P0133
Signal - Upstream oxygen sensor P0131 - P0132
Oxygen sensor heating control (upstream of the catalytic converter) P0135
Signal - Downstream oxygen sensor P0137 - P0138 - P0139 - P0136
Oxygen sensor heating control (downstream of the catalytic converter) P0141
Fuel injection P0170
Petrol injector N° 1 control P0201 - P0262 - P0261
Petrol injector N° 2 control P0203-P0268 - P0267
Petrol injector N° 3 control P0204 - P0271 - P0270
Petrol injector N° 4 control P0202 - P0265 - P0264
Accelerator pedal sensor ; Incoherence of signals 1 and 2 P0221
Accelerator pedal sensor ; 1 signal P0222 - P0223 - P0220
Accelerator pedal sensor ; 2 signal P0227 - P0228 - P0225
Ignition misfiring on more than one cylinder or cylinder unknown P0300
Ignition misfiring (cylinder n° 1) P0301
Ignition misfiring (cylinder n° 2) P0302
Ignition misfiring (cylinder n° 3) P0303
Ignition misfiring (cylinder n° 4) P0304
Signal - Knock sensor P0326 - P0327 - P0329 - P0325
Signal - Engine speed sensor P0336 - P0338 - P0335 - P0339
Cylinder reference sensor 1 P0341
Ignition coil 1 control P0351
Ignition coil 2 control P0352
Ignition coil 3 control P0353
Ignition coil 4 control P0354
Air pump relay control P0413 - P0414 - P0412
Catalytic converter ageing P0420
Fuel vapour recycling P0440
Canister purging electrovalve control P0444 - P0445 - P0443
GMV operated at fast speed : 1 electric cooling fan unit (relay) P0480
GMV operated at fast speed : 2 electric cooling fan unit (relay) P0481
Signal - Vehicle speed sensor P0502 - P0503 - P0500
Air conditioning pressure P0532 - P0533
Power steering stop information P0551 - P0553
Battery voltage P0562 - P0563 - P0560
Cruise control switch information P0568
Petrol injection ECU P0606 - P1152 - P0601
Butterfly position check P1161
Butterfly position incoherence ; Track N° 1 / pressure P1133 (*)
Butterfly position incoherence ; Track N° 2 / pressure P1134 (*)
Inlet manifold P1160 (*)
Control - Motorised butterfly housing P1150 (*) - P1151 (*) - P1154 (*) - P1155 (*)
Motorised throttle ; Incoherence of signals 1 and 2 P0121
Initialisation of the butterfly stops P1153 (*)
Butterfly position sensor ; 2 signal P1157 (*) - P1158 (*) - P1156 (*)
Cooling fan status P1507 (*) - P1519 (*) - P0483 - P0485
Coded engine immobiliser generation 2 P1612 (*)
Fault internal to the engine management ECU P1617 (*) - P1631 (*)
System fault P1621 (*)
Sensor supply P0608 - P0609
GMV operated at low speed : 2 electric cooling fan unit (relay) P0481
The engine ECU no longer communicates on the network U1000
Engine ECU supply P1601 - P0215
Remote Controlled Wake-Up (RCD) : Main wake-up fault U2000
Remote Controlled Wake-Up (RCD) : Partial wake-up fault U2118
Remote Controlled Wake-Up (RCD) : Incoherence between main wake-up and electrical signal U2003
Pressure / butterfly position not coherent P0105
Piloted Alternator mechanics P1674
Piloted Alternator electrics P1675
Communication with the piloted alternator P1676
Piloted thermostat control P0597 - P0598 - P0599
Accelerator pedal point of resistance information (Speed Limiter) P1614 - P1645 - P1643 - P1644
ECU not downloaded P0602
Engine running information P1657 - P1656 - P1655
Electric fuel gauge P250C - P250D - P250B
Configuration P1613
Cruise control P1671
Speed limiter P1607
Dialogue with the Stop and Start ECU U1103 - U1203
Fuel gauge P0461 - P0463 - P0462
Non coherence between the 2 stop switches P0571
Variable timing electrovalve P1148 - P0075 - P1149 - P0076 -P0077 - P0012 - P0011 - P0010*
Incoherence between inlet pressure and butterfly angle information P1622 (*)
Engine torque delivered P1623 (*)
Incorrect ESP demand P1624 (*) - P1625 (*)
Incoherent information relating to the automatic gearbox P1626 (*)
Non respect of the torque demanded by the driver P1627 (*)
Incoherent information from the brake switch or accelerator pedal sensor P1628 (*)
Incoherence between calculated mechanical friction and actual friction P1629 (*)
Incoherent cruise control demand P1630 (*)
No communication on the network U1003 (*)
Dialogue with ABS or ESP U1113 (*) - U1213 (*)
Dialogue with the BSI U1118 (*) - U1218 (*)
Dialogue with the automatic gearbox U1209 (*) - U1109 (*)
(*) "constructor" faults
