dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 4070 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
בוקר טוב,
ראיתי בכמה מכוניות קונקטורים חשמליים שונים שמגיעים מלאים בגריז מפס הייצור.
הגריז בתוך הקונקטור נועד כנראה לדחות לחות.
שאלות:
1. באיזה גריז משתמשים?
2. לאיזה מטרה בדיוק הוא נמצא שם?
3. מדוע רק חלק מהיצרנים משתמשים בזה?
4. האם כדאי למלא בגירז קונקטורים שמגיעים במקור ללא גריז?
תודה.
Dielectric grease
Dielectric grease is electrically insulating and does not break down when high voltage is applied. It is often applied to electrical connectors, particularly those containing rubber gaskets, as a means of lubricating and sealing rubber portions of the connector without arcing.
A common use of dielectric grease is in high-voltage connections associated with gasoline engine spark plugs. The grease is applied to the rubber boot of the plug wire. This helps the rubber boot slide onto the ceramic insulator of the plug. The grease also acts to seal the rubber boot, while at the same time preventing the rubber from becoming stuck to the ceramic. Generally spark plugs are located in areas of high temperature, and the grease is formulated to withstand the temperature range expected. It can be applied to the actual contact as well, because the contact pressure is sufficient to penetrate the grease. Doing so on such high pressure contact surfaces between different metals has the advantage of sealing the contact area against electrolytes that might cause rapid galvanic corrosion.
Another common use of dielectric grease is on the rubber mating surfaces or gaskets of multi-pin electrical connectors used in automotive and marine engines. The grease again acts as a lubricant and a sealant on the nonconductive mating surfaces of the connector. It is not recommended to be applied to the actual electrical conductive contacts of the connector because it could interfere with the electrical signals passing through the connector in cases where the contact pressure is very low. Products designed as electronic connector lubricants, on the other hand, should be applied to such connector contacts and can dramatically extend their useful life. Polyphenyl Ether, rather than silicone grease, is the active ingredient in some such connector lubricants.
Silicone grease should not be applied to (or next to) any switch contact that might experience arcing, as silicone can convert to silicon-carbide under arcing conditions, and accumulation of the silicon-carbide can cause the contacts to prematurely fail. (British Telecom had this problem in the 1970s when silicone Symel® sleeving was used in telephone exchanges. Vapour from the sleeving migrated to relay contacts and the resultant silicon-carbide caused intermittent connection.)
Stay Dirty
אסף תודה אבל חיפוש באינטרנט אני יודע לעשות ואפילו עשינתי לפני שפתחתי את השירושור.
מעוניין לשמוע מה אומרים אנשים אמיתיים כאן :-D
ולגבי הקטע שציטטת - אני לא מדבר דווקא על שימוש במחברים של פלגים במתח גבוה ובטמפ' גבוהה אלא על שימוש במחברים 12V שעובדים בתנאי טמפ' רגילים.
Dielectric grease, משתמש בו כבר הרבה זמן, בחיבורים שונים של חיישנים במיוחד איפו שיש לחות ומים (חיישני מהירות על הגיר ושאר הירקות).
מגן בפני קורוזיה ומגן על החיבור מפני מים.
דוגמה טובה: בהונדות ישנות כאשר שוטפים את המנוע או פוגעים אם קצת מים על הגיר (ידני) נדלקת נורה בדוק מנוע-תקלה בחיישן מהירות שימוש בגריז הנ''ל יפתור את הבעיה ומים לא יחדרו לחיבורים של החיישן.
בצבא הייתי מתקן תיבות אלקטרוניקה שהיו מגיעות מחיל הים. הם מצפים את המחברים בגריז. ממה שאני הבנתי, השתמשו בגריז הפשוט ביותר (זה שמגיע בפחיות של כמה קילוגרמים). כנ"ל מחברי RF כדי להמנע מקורוזיה שנכנסת לתוך הכבלי RF. כבל RF שנכנס אליו מים מאבד חלק גדול מהיעילות שלו.
יש כזה גריז יעודי של רנו ומשתמשים בו בסלילי הצתה.
לא זוכר מק"ט של זה אבל אני יחפש אם זה חשוב למישהו.
בכל מקרה אני משתמש בו רק במקומות שאני חושש לחדירת לחות לקונקטו רולא שם אותו סתם ככה איפה שלא צריך
על מצבר שמים בד"כ וזלין, זה פחות מלכלך. גירוז קונקטורים ובמיוחד כבלי הצתה די נפוץ ברכבי שטח בנזין שרוצים לצלוח מים כדי שלא ידומם המנוע.
עז יפנית בסלעים | yahav.biz
