כל מה שפורסם על ידי proxima
עלויות אחזקה בC3? טימינג? צריכת דלק? טיפול קטן מאד יקר ראיתי קבלה על 1100 ש"ח
proxima פרסם הודעה בנושא של AORPAZ911 בתוך ייעוץ ברכישת רכב
לקונטיקונטקט יש רצועות טיימינג לכל אורך חיי המנוע, נראה לי שגם לגייטס , השיפור עצום בשנים האחרונות, בקונטי ביחד עם חברה קנדית פותח גלגל שיניים אליפטי לחגורה שמפחית את הלחץ עליה, רעיון פשוט וגאוני. Beijing, April 2008ContiTech develops innovations for pump injector and oval sprocket technology "With a whole series of innovations, in the last few years ContiTech has significantly improved the performance of timing belts", reports Hermann Schulte, Head of Development for timing belt drives at the ContiTech Power Transmission Group in Hanover. They can be seen from 20 to 28 April at the Auto China 2008, on the Continental Corporation's combined stand (Hall W7, booth K02). "Today's customers demand maintenance intervals that are as long as possible or even completely maintenance-free engines", explains Schulte. At the same time, engine life is increasingly rapidly. In the 1980s, a service life of 100,000 kilometers was required but now the standard figure is 240,000 kilometers. Volkswagen realizes the pump-injector unit on its TDI engines using the latest-generation timing belt technology from ContiTech. Photo: ContiTech Image Download (JPG, RGB, 300dpi, app. 10x7cm, 705kB) Since the introduction of the overhead camshaft in the 1970s, timing belt drives for synchronization of the camshaft and crankshaft have won a market share of 75 percent. While timing belts have always been lighter, quieter and cheaper than chain drives, they have now caught up in terms of service life. The timing belt’s other major advantages are drive design flexibility and low-friction running. The belt can be routed via any number of deflection pulleys for auxiliary drives. Due to the high-friction tensioning technology, chains require more space. And some of today's engine solutions would not even be possible with chains. Volkswagen realizes the pump-injector unit on its TDI engines using the latest-generation timing belt technology from ContiTech. Thanks to the pump-nozzle injection technology, engine performance and service lives are now possible with an injection pressure exceeding 2,000 bar – something that could not be achieved either with conventional timing belts or chains. During injection on the Golf TDI, up to 4.5 kN is pulling on the CONTI HSN-POWER® timing belt, which is not permitted to stretch by more than a few tenths of a millimeter. Pump injector technology results in around five percent more power, a 20 percent increase in torque and lower harmful emissions. Another revolutionary technological innovation in the use of timing belts in vehicles is oval sprocket technology, developed jointly by ContiTech and the Canadian Litens Automotive Group. The sprocket is slightly oval rather than circular. This results in intentional counter forces in the timing belt, which reduce the peak forces caused by the valve drive. In this way fluctuations in belt tension and constant velocity are minimized. Oval sprocket technology brings about a forty percent reduction in the forces acting on an engine’s timing belts and components. This further extends the belt service life and also reduces fuel consumption and noise. The new technology will be used for the first time in Audi TFSI engines and in the Golf V. In all current timing belt drive development projects, the standard is to design the belt for the service life of the engine. "Our innovations, such as the CONTI HSN-POWER® timing belt, feature cold start capability down to -40°C, high dynamic and static temperature resistance up to 150°C, briefly up to 170°C, a compact construction, good wear resistance and noise minimization, plus a long service life", summarizes Schulte. -
פרייאר מי שקונה בסכומים כאלו כמות מסכנה של דיו. אפשר לקנות כמות פי 10 באותו מחיר של מקורי אחד.
לא מדובר ברעשים של חלק לא מתפקד. מדובר ברעש נורמלי של חלק העושה את עבודתו בחריצות יתרה.
יש דרך להחליף תושבת מנוע תחתונה בפיג'ו 306 ללא פירוק צירייה ?
proxima פרסם הודעה בנושא של proxima בתוך טכני, אחזקה וטיפולים
טוב מצאתי , תודה לי. -
ניקויי החיישן אצלי אכן הביא לשיפור בעצירה שהיתה ארוכה, כרוך ביותר מפירוק גלגל, ולחץ אויר לא תמיד עוזר , מאחר ונתקלתי כבר בחיישנים מכוסים בבוץ דביק שהתקשה .צריך לנקות את החריצים של הטבעת המשוננת שהחיישן מודד בעזרת את מהירות הסיבוב .
בדקתי , יש SP1 .
ול BJ and the rest of the high hills pitbulls אני אומר !NO MAA'M National Organisation of Men Against Amazonian Masterhood pz-qN9aIm9k דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
איזה יופי, התחלתם להתחבר לצד הגברי שלכם סוף סוף, אז נמשיך עם קרובת משפחה נוספת שהלכה לאיבוד :
מורל ? אחת מחמש הטובות בעולום? נחשבת ע"י מי ?
לוח בקרה-> הסר התקן תוכניות, מחפש ברשימה SP1.
מוזר... הזמנתי כזו ,ועוד היה כתוב תמונות אמיתיות ! איפה מתלוננים ?
אתם נסחפים , המטרה היתה להמליץ על מוצרים ישראליים איכותיים שרוב חברי הפורום יכולים ומעונינים לקנות אך לא מודעים לקיומם, מתקן התפלה,מרגמות,טנקים ,טילים ומל"טים לא בדיוק מתאימים להגדרה כמוצרי צריכה המוני , בירה ובוקסות - כן.
לפטופ חדש בן 3 חודשים מבית טושיבה, אני כבר לא זוכר אם התקנתי SP1 , תיכף אבדוק ואדווח, הבעיה שטושיבה ארזה ביחד עם ויסטה עוד כמה אפליקציות מיותרות , היום העפתי ליתר בטחון את הגוגל דסקטופ מתוך חשש לפעילות תוכנת האינדוקס ברקע . עדיין הקשיח פעיל ללא שום התגרות מצידי.
עם שמן . אפקוסי יבש נעשה נקבובי מאוד , תספיג אותו בשמן היטב עד למלוא כושר הספיגה , ואז נסה בעדינות לפורר .
ייעוץ בנוגע לשמן הגה כוח, אאודי 80 שנת 95 אוטו'
proxima פרסם הודעה בנושא של erezfed בתוך טכני, אחזקה וטיפולים
עד כמה שזכור לי יש שיטה שהשתמשתי בה פעם : ניתוק אחד משני הצינורות היוצא מהמיכל (לא זוכר בדיוק איזה , אמצא את ההסבר ואעלה אותו מאוחר יותר) וניקוז הנוזל ע"י הפעלת סטרטר, (זה מתאים כשאין קשר לגיר). -
טוב, הזמנתי אחרת .
בוא נניח שמדובר באחד מרכבי הפרוייקטים בפורום שיפורים המצויד בצמיגים רחבים , מונמך היטב עם אפקט קרקעי ואיטי .
פרה של עלית ??? מילא היית אומר ספלנדיד בטעם קפה חוף השנהב שלהם , אבל פרה ?. מתקני התפלה ביתיים? כי זה לא בדיוק משהו שהולך עם צרכן פרטי (כנ"ל רפאלי , אלא אם כן היא בצרות והחליפה מקצוע) משחררי אויר ? זה קשור לשעועית ? . כנ"ל ברמד. דובר על מוצרים מסחריים לצריכה פרטית (פיקסלים של רפאלי למשל נכללים) .
נכון , אבל ורטהיימר מנייק, הוא דופק לקליינטים הישראליים מחיר מופרז לעומת התמחור שלו בחו"ל .
זה הנעלם ! מנ"א ? לגבי אפשרות ההאצה זה תלוי : אם הוא סדיסט - כן , סתם טמבל - לא בטוח , האוטו צרפתי - בטוח , אבל לא ידוע אם יצליח להגיע ליונה .
1) אם היא לא הבחינה, היא תדרס בכל מהירות , לא ברור ? 2) ר' 1) , אם את מתעקשת על הכללת תנאי קצה פתולוגיים. 3) שניה וחצי בערך. 4) שניה ו - 3/4. 5) "סדיסט" ו- "סתם טמבל" זה לא PC , אמרי "מאותגר אתית/רגשית" או "סתם מאותגר חיבוריות לצד הנשי".
נגיד ואתם נוהגים בכביש החוף ראות חלקית/מלאה ,לילה ,גדר טובה... ואתם מבחינים (או בוחרים לא לראות) ביונה במרחק 50 מטר ממכם נחה על האספלט. בהנחה שלא בא לכם להאט, מה המהירות הדרוסה בה היונה לא תספיק להמלט ?
OZAT מעולים ,מוכר יקה זקן בחנות אספקה טכנית לחש לי על האוזן. עוד מוצר שממלא את כרסי בגאווה : בירה ממבשלת כנען בירושליים , אחת הבירות המדהימות ביותר שהערתי לתוכי , יש ב"טיב טעם" ומחסני שתיה, להתחיל להפעיל לחץ בפאבים ובחנויות, הבירה הזו שווה כל אגורה (13ש"ח ל3/4 ליטר הבקבוק) .
בת הדודה שהזמנתי יצאה במונית מת"א לכיוון נתניה. בגלל שהיא לא מדברת כמעט מילה בעברית (שלושה שבועות בארץ ויומיים בסיני) היא לא ירדה מהמונית בזמן ועוד כמה דקות היא מגיעה לחיפה. יש פיתרון כלשהו? היא צריכה להגיע אלי דחוף!. מישהו יכול לנדב לה ספה ללילה ...(בעצם לא!) או לתת לה טרמפ בחזרה לנתניה? הדלק עלי . בת הדודה __________________
