תוספת קטנה
לפי האתר הזה -https://www.carwow.co.uk/news/seat-leon%20cupra-07-09-2270
השיפור הוא גם במשהו שקשור לבוכנות , סעפת יניקה ,כיול מערכת dcc,שינוי קל בפנים הרכב ,וסואנד יותר ספורטיבי...
"The boost in performance is due to a bump in the 2.0-litre turbo engine’s power output from 276hp to 286hp. This increase comes courtesy of to tweaked components within the engine; a new coating for the pistons reduce friction, while more efficient heat management from the exhaust system plays a part, too. The latter has also been tweaked at the noisy end, and SEAT says it makes a more tuneful note than the model it replaces.It isn’t just the power output that has improved though – while the 258lb ft peak torque figure is the same as before, it is now spread across a wider range of the power band, helping in-gear flexibility.
What else is new?
A little extra tech aims to sharpen up the driving experience relative to the outgoing model. Thanks to the inclusion of what SEAT calls Dynamic Chassis Control, the driver can alter the response of the dampers, enabling stiffer settings for performance driving and softer settings for a more relaxed cruise. Progressive steering is now also included as standard. This system adjusts the sensitivity of the power steering according to road speed, lightening up for parking manoeuvres and weighting up at higher speeds for a greater feeling of stability.
