205 GTI 1.9
Engine: 4 cylinder, in-line, aluminium block with replaceable liners, aluminium alloy cylinder head, Five main bearings, Single overhead camshaft driven by toothed belt, Bosch L-Jetronic fuel injection.
- 1986 - 1993 (Type XU9JA)
1,905cc, bore 83mm, stroke 88mm, compression ratio 9:6:1, 130bhp (DIN) at 6,000rpm, 119lb.ft @ 4,750rpm.
- 1990 - 1994 (Type XU9JAZ) (Catalyst equipped)
1,905cc, bore 83mm, stroke 88mm, compression ratio 9:2:1, 122bhp (DIN) at 6,000rpm, 111lb.ft @ 4,000rpm.
Transmission: Five-speed, all indirect, with synchromesh.
Ratios (mph per 1000rpm): 1st 2.92 (6.2); 2nd 1.85 (9.; 3rd 1.36 (13.3); 4th 1.07 (16.9); 5th 0.86 (20.9). Final-drive ratio 3:69:1
Suspension: Front: Independent with MacPherson struts, coil springs, lower wishbones and anti-roll bar. Rear: Independent with trailing arms, transverse torsion bars, telescopic shock absorbers and anti-roll bar.
Steering: Rack and pinion, 3.2 turns from lock to lock.
Brakes: Front: 9.7in diameter ventilated discs. Rear: 7.1in solid discs. Vacuum servo.
Wheels: 6.5J-15in diameter cast-alloy, with 185/60HR-15 radial-ply tyres. Tyre pressures 29psi front and rear.
Capacities: Fuel tank: 11.0 gallons (50 litres). Cooling system: 11.6 pints (6.6 litres). Engine sump 8.8 pints (5.0 litres).
Dimensions: Overall length: 145.9in Overall width: 61.9in. Overall height: 53.3in. Wheelbase 95.3in. Front track: 54.4in. Rear track: 52.7in. Maximum payload: 960lb. Kerb weight: 1,929lb
קצת חיפושים ברשת ,עצלן !
