adidas1
כל מה שפורסם על ידי adidas1
  1. Transporter, ברשותך, אסביר כאן מה לעשות ולא בפרטי כדי שעוד אנשים יוכלו להעזר בזה. יש כאן דף עם לינק לתוכנה שניתן להשתמש בה על מערכות ווינדוס, יש גם לינק למסמך PDF שמתאר את כל האופציות של המצלמה. אתה שאלת לגבי איך לשנות הגדרות אם אין לך מערכת ווינדוס, העתקתי את ההוראות מתוך מסמך ה PDF: On Windows it is recommended to always use the program mSetup.exe to modify the camera's configuration. mSetup communicates directly with the camera and makes configuring the camera a very simple task. It is, however, also possible to manually change the configuration settings by editing the "SYSCFG.TXT" file which must be placed in the root folder of the card for the camera to find and load the new settings. You can use any ASCII editor, for example Notepad, to modify the parameters. The "SYSCFG.TXT" must be in plain ASCII, it must not be in Unicode. If you don't know what a root folder is, or you don't know what ASCII is or don't know how to manually edit ASCII files please only use mSetup.exe. A "SYSCFG.TXT" file must first be generated by theCamera. The camera's parameters are self explanatory. It is important not to change the sequence of the square brackets and not configure invalid combinations. For example, never combine a clip longer than 5 minutes with the continuous loop. If you enter invalid combinations or values, the Camera will not perform as expected. It is much safer to use the setup programwhich will always configure the camera correctly. The "SYSCFG.TXT" file can be automatically generated as follows: 1. Disconnect the camera from the PC and turn it off. 2. Press and Hold Down the Mode button. DO NOT RELEASE the button until step 4. 3. Press and Hold Down the Power buttonuntil the RED LEDblinks 3 times and the camera turns off. This will take about 5 seconds. During the process, the blue and yellow LEDs may blink. 4. Release the Mode and Power buttons. The SYSCFG.TXT file showing the camera's current settings should now be in the memory card root folder. Now you can edit the SYSCFG.TXT file as indicated above, and load the new settings back into the camera by using exactly the same method as outlined in steps 1 through 4, above. Once completed, the "SYSCFG.TXT" file will be automatically deleted from the card's root folder.
  2. מפנה אותך שוב למה שכתבתי על המצלמה הזו: http://www.carsforum.co.il/vb/showthread.php?p=4006674#post4006674 לשאלותיך, איפה הכי מומלץ? זה עניין של שלך בלבד, אני שמתי אותה מתחת למראה הקדמית, יש כאלה שיעדיפו לשים מאחורי המראה. הגדרות המצלמה מתבצעות עם תוכנה שבעזרתה ניתן לשלוט על ההגדרות, מה הבעיה? התוכנה הזו ממותאמת למערכות הפעלה של Windows אז או שתצבע את ההגדרות על Windows או שתשתמש בשיטה של הגדרה דרך קובץ. איך לוודא שהתמונה ישרה? אפשר לחבר את המצלמה למחשב עם הכבל שמצורף ולדוק שהתמונה ישרה או להוציא ת כרטיס הזיכרון, להכניס אותו למתאם SD ואז למחשב כדי לבדוק שהתמונה ישרה. כמו שהמליצו למעלה, כנס לאתר rcgroups, יש בפוסט הראשון את כל המידע, רק צריך לקרוא קצת.
  3. נתקלתי היום בסרטונים שהעלה אחד החברים באתר detailingworld. בסרטונים האלה הוא מסביר על איך בנוי הצבע על הרכב, אילו שריטות ניתן להוריד עם פוליש ואילו לא, כיצד להשתמש במכונת פוליש, סוגי פדים שונים, כמה חומר פוליש לשים על הפד ולמה לא לשים יותר מדי, כמה לחץ להפעיל על המכונה וכו'. חייב לציין שהוא חידש לי הרבה, מעניין מאוד. הנה הלינק לשרשור עצמו למי שמעוניין. KP-eAddv2sk דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed. h_0nr6XPEHM דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed. PyJYtYhz9RQ דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed. P0rbZOeNN4o דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed. zuGMg0wwo6E דרך יוטיוב ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
  4. Doras, הייתה לי גם הבעיה הזו, תנסה לעשות פורמט לכרטיס דרך המצלמה ואז תשנה את זמני כתיבת הקבצים לשלוש דקות. אגב, כן יש שם אופציה של loop record, תוודא שהיא מסומנת אצלך.
  5. אני אישית משתמש בחומר של Astonish לחלונות (צבע כחול), בעזרת מטלית מיקרופייבר וופל מנקה את השמשה, מעביר עוד ניגוב עם חומר דוחה אדים של american eagle שאפשר לקנות בהום סנטר במחלקת הרכב, מגיע בספריי קטן. החומר אכן עושה את העבודה, לא נוצרים אדים על השמשה, אני רק לא יכול להגיד כמה זמן הוא מחזיק, קניתי אותו רק לפני כמה ימים. מה שכן, אם משתמשים במגבת מיקרופייבר איכותית כמו כאן לא יהיו סימני מריחה.
  6. misterb, דבר נוסף, אני לא יודע באיזה כבל USB השתמשת אבל זכורות לי כמה בעיות שדובר עליהן ב rcgroups של אנשים שהשתמשו בכבל USB לא מקורי.
  7. אני אתמקד במצלמת דרך, מצלמות רוורס אני לא מכיר. לגבי מצלמות דרך (מצלמה קדמית) את יכולה להסתכל בשרשור הזה: http://www.carsforum.co.il/vb/showthread.php?t=440339 מציע לך דווקא להתחיל מהדפים האחרונים, עברו הרבה מים בירקון מאז שהשרשור נפתח. יש פה גם כמה פרמטרים, מצלמה שמתאימה לי לא בהכרח מתאימה לך, יש כמה שאלות כגון מה התקציב שלך, מצלמה עם או ללא מסך תצוגה וכו'. אני אישית ממליץ על מצלמת ה Mobius שסיקרתי כאן: http://www.carsforum.co.il/vb/showthread.php?p=4006674#post4006674 לגבי קדיחות, עד כמה שידוע לי אין צורך, מה שכן, יש צורך בעבודת חשמל פשוטה שכל חשמלאי רכב יכול לעשות ומשם זה רק העברת חוטי המצלמה בצורה שלא תהיה בולטת. באותו לינק שהבאתי לך למעלה תוכלי לראות התקנה שאני ביצעתי ואני לא חשמלאי או מתקין מערכות מדופלם. בהצלחה,
  8. misterb, מזל טוב על קבלת המצלמה, אכן מצלמה מצויינת. הפרספקס שהכנת נראה מעולה, אני אישית עדיין מעדיף את הזרוע שנדבקת עם דבק דו"צ של 3M, ככה אפשר גם לשלוט על הזווית של המצלמה. אני מבין שראית את השפצור של 2 הבליטות באתר rcgroups, שם הציעו בדיוק אותו פתרון כדי להקל על השליפה של המצלמה מהתושבת.
  9. כדי לפרמט מכשיר לגמרי זה מה שצריך לעשות וזה מה שאני עושה: 1. Wipe data 2. Wipe system 3. Wipe cache 4. Wipe dalvik cache בנוסף אני נכנס עם מנהל קבצים ומוחק את כל התיקיות שהשאירו אחריהן תוכנות, משאיר רק את התיקיה של התמונות.
  10. מנהל הקבצים הטוב ביותר Root Explorer: https://docs.google.com/file/d/0B4PjYmho9VxzelFzUlJBQld4Y1U/edit?usp=docslist_api
  11. אתה לא יכול להקליד פשוט בגוגל "היסטוריית טיפולים + מספר רכב", אתה צריך ללכת למוסך שבו טופל הרכב ושם להוציא את היסטוריית הטיפולים. אגב, חבל שלא וידאת היסטוריית טיפולים לפני שרכשת את הרכב כדי לדעת האם הוא טופל בזמן.
  12. תגידו, האנשים שמבלים את רוב זמנם כאן בפורום דיטיילינג, אתם מסודרים ונקיים גם בבית או שהניקיון נוגע רק לרכב? אפשר להגדיר אותנו כאנשים בעלי OCD בדרגה כזו או אחרת? יש לי הרגשה שאנשים שאוהבים לנקות ולדאוג שהרכב יהיה נקי כל הזמן הם אנשים מסודרים ונקיים באופן כללי, לא רק כשזה נוגע לרכב. אני צודק? גם הדירה שלכם נראית כמו מוזיאון? לפחות לגבי אני יודע שזה נכון.
  13. אני רכשתי אתמול את Meguiar's Natural Shine Protectant באוטוסטור, עדיין לא ניסיתי אותו אז אני לא יכול לחוות דיעה.
  14. adidas1
    מה עושים עם הנדחפים ?
    שמתי לב לאחרונה דווקא שהרבה מהנדחפים ואלו שנוסעים מהר ומזגזגים הן דווקא נשים. לפעמים אני רואה רכב נוסע במהירות ובצורה מסוכנת או רכב שנדחף לראש התור בצורה מגעילה, אני די בטוח שזה איזה גבר ערס, אבל כשאני מסתכל לתוך הרכב אני רואה אישה.עדיין קצת קשה לי להבין איך נשים יכולות להתנהג ככה.
  15. תנסה לעשות פורמט לכרטיס זיכרון דרך המצלמה, נסה להוציא את הכרטיס ולהכניס שוב למצלמה.
  16. doras, תכנס להגדרות המצלמה ותעבור עליהן, עד כמה שזכור לי יש שם הגדרות לזמני קבצים.
  17. אהלן, לגבי ה WDR, לא עשיתי השוואה אבל ממה שקראתי ב rcgroups ממליצים לא להפעיל אלא אם כן אתה מצלם רק בתנאים חשוכים, אחרת בצילום באור יום זה לא ישפיע על הצילום לטובה. לגבי ה bitrate, גבוה יותר אמור לתת איכות וידאו טובה יותר, לא יודע אם תבחין בזה ממש. זה גם עניין של מקום על כרטיס הזיכרון, בכרטיס זיכרון של 16G צילום בסטנדרד יתן לך 2.4 שעות של צילום, בהגדרה של High תקבל שעתיים של צילום, הבדל של 40 דקות, בסה"כ לשיקולך. אני אישית כיביתי את ה WDR ושמתי בביטרייט על High.
  18. הנה התקנות שאני עשיתי: http://www.carsforum.co.il/vb/showthread.php?p=3730932#post3730932 http://www.carsforum.co.il/vb/showthread.php?p=4006674#post4006674
  19. עד כמה שידוע לי אין קנסות. אתה צריך לשמור את טופס ביטוח החובה המקורי שלך ולשלוח אותו לחברת הביטוח. אתה תקבל בדואר צ'קים עם החזרים כספיים.
  20. כן, כיוון שבקובץ ה ZIP של התקנת ה ROM החדש קיים הקובץ הישן והוא ידרוס את הקובץ החדש שעכשיו העברת. אתה גם תוכל לוודא זאת ע"י שתפתח את הקבצים עם כל NOTEPAD, אפשר גם עם ה Root explorer ששלחתי לך ותראה שהתוכן שונה.
  21. ישנה גם בעיה מוכרת ברנו מגאן שבזמן שהרכב מונע והוא קר נשמעים רעשים מאזור המנוע, זה נגרם בגלל הדיפייזר. לא יודע אם זה המקרה אצלך, בכל מקרה תוכל לקרוא כאן.
  22. אחלה, שמח שעזרתי. שים לב שאם אתה מעדכן לגרסאות Nightly או כמובן מתקין ROM חדש יש לחזור על העתקת הקובץ ושינוי ההרשאות. אם אתה מתקין ROM חדש יש לעשות את 2 השלבים, העתקת הקובץ ושימוש בתוכנה gps test.
  23. אני לא יודע עם איזה סייר קבצים אתה עובד, תתקין Root explorer מכאן, לך שוב לקובץ, קליק ארוך על הקובץ, תבחר Owner ושים בשתי האופציות root. שוב קליק ארוך על הקובץ, תבחר ב Permissions, תן את אותם הרשאות כמו אחד הקבצים באותה תיקייה, פשוט תראה מה ההרשאות ותעשה אותו דבר.
  24. אתה צריך הרשאות ROOT על המכשיר. במידה ויש לך, אתה צריך לגשת לתיקייה העליונה בהיררכיה של מערכת הקבצים שגם נקראת Root והיא מסומנת ע"י '/', משם אתה ניגש לתיקיית system ומשם לתיקיית etc.
  25. אהלן MC ofer, צירפתי לפוסט שלי קובץ שנקרא gps.txt, אתה צריך להוריד אותו למכשיר האנדרואיד שלך ולשנות לו את הסיומת ל conf.
