אלו נתוני המגבר:
14.4V Rated Output Power (4 Ohm, 20 ~ 20 kHz), 1% THD: 4 x 60 W
14.4V Rated Output Power (2 Ohm, 1kHz), 0.8% THD: 4 x 90 W
14.4V Bridged Output Power (4 Ohm, 1kHz), 0.8% THD: 2 x 180 W
14.4V Maximum Output Power (4 Ohm, Bridged): 720 W (4 x 180W)
Built-in Variable Low-pass Filter, B Channel: 50-200Hz (-12dB/oct)
Built-in High-pass Filter, A Channel: 80Hz (-12dB/oct)
Variable input sensitivity: 0.2 ~ 5 V
Frequency response: 10 ~ 50 kHz
Signal noise ratio:
Maximum current consumption: 21 A
Dimensions (WxHxD): 330 x 59x 230 mm
Weight: 2.6 kg
2 Ohm Load Capability
Aluminum Die-casting Heat Sink
Cooling fan
Speaker Level Input
RCA Line Input Terminals
Power MOSFET Switching Power Supply
ומחיר המגבר בחו״ל הוא בערך 750₪
למה אתה שואל אם אפשר לשאול?
