Jl audio g4500
1000 ש"ח
4-channel car amplifier
at 14.4 volts:
80 watts RMS x 4 at 4 ohms (125 watts RMS x 4 at 2 ohms)
250 watts RMS x 2 bridged at 4 ohms (160 watts RMS x 2 at 8 ohms)
at 12.5 volts:
60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
180 watts RMS x 2 bridged at 4 ohms (120 watts RMS x 2 at 8 ohms)
2. מגבר cerwin vega xl150.2 מונובלוק
350 ש"ח
2 x 75 watts into 2 ohms @ less then 0.1% THD
2 x 50 watts into 4 ohms @ less then 0.1% THD
Vega Bass! Boost Control
High Current MOSFET power supply
Audiophile Class A/B Bipolar Output Stage
Variable 12dB/oct Highpass/Lowpass Crossover
High Level Speaker Inputs
Thermal and Overload Protection
3. מגבר HIFONICS TITAN 4ch
800 ש"ח
Titan TXi Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 85 watts x 4 chan.
2 ohms: 170 watts x 4 chan.
Bridged, 4 ohms: 340 watts x 2 chan.
Pulse width modulated (PWM) MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
Bridgeable operation
Speaker-level inputs
Soft turn-on circuitry
Preamp RCA outputs
DC, short, thermal, and overload protection circuitry
Variable input level control
Illuminated Hifonics badge
Heavy duty aluminum alloy heatsink
Variable high-pass filter (60-1200 Hz, 24 dB/octave)
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Frequency response: 30-1200 Hz
Dimensions: 14.17"L x 9.07"W x 2.36"H
4. JL AUDIO 250/1 MONOBLOCK
נמכר, ברכות לקונה ש"ח
Class D Circuitry
250W RMS @ 1.5 ohms - 4 ohmsTHD at Rated Power:
S/N Ratio: >95dB below rated power
Frequency Response: 5 - 50,000 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Dimensions: 10.25"L x 9.25"W x 2.36"H
5. מגבר Lightning Audio s5.700
נמכר, ברכות לקונה
נתונים באתר
http://www.sonicelectronix.com/item_684_Lightning-Audio-Strike-S5.700.html
הקפצה עם עדכון מחירים!
מספר פלאפון: 0528736840
