matanff
כל מה שפורסם על ידי matanff
  1. אז מאיפה כל הביקורות החיוביות שיש למוכר הזה? אל תבין אותי לא נכון, אני איתן ואני מבין שיש פה משהו מסריח, אבל איך זה הגיוני? אתה יכול להסביר לי מה זה נקישות ודטונציות(detonations?
  2. לא ראיתי כאן תגובה אחת שאומרת שזה ישפר ביצועים במנוע אטמוספרי, לעומת זאת, המוכר בEBAY מבטיח 10-20 כ"ס וצריכה דלק משופרת (1-3 מיילים יותר לגאלון) שימו לב מה הוא כתב לי: Hello, Thank you for your e-mail! Yes, we fully guarantee that you'll see a positive improvement with your 2008 Honda Jazz! All of our products are incredibly simple in design and the way that these basically work is by sending a lower-valued signal through a factory engine data sensor, called the IAT sensor. As you may know, the IAT sensor is directly interfaced with the factory ECM (Engine Control Module) and your factory ECM controls fuel and timing based on the current value of the IAT sensor. By lowering the value of the IAT sensor using our products, you're basically triggering your factory ECM to reprogram itself for a more efficient tune - and since our products aren't touching anything directly nor setting any fixed settings, all changes are dynamically calculated and performed completely by your factory ECM, which means that these are also VERY safe to use as everything has to go through all of the sophisticated factory built-in sensors and safeguards! All in all, I would certainly expect around our typical gains with your vehicle, usually anywhere from up to 1-3 MPG and anywhere between 10-20 HP. If you check out our feedback profile, there are countless customers who have posted their actual gains (performance/fuel mileage) seen with our products - this truly speaks MUCH more than any number that we could ever claim! We fully guarantee that you'll see positive improvements either in performance and/or fuel economy in your vehicle, so if you're interested in trying our product then please feel absolutely welcome to take advantage of our 100% Money-Back Guarantee and see how our product works out for you! If you have any other questions, then please feel welcome to e-mail us and we'll be happy to answer any questions that may arise! Thank you, Best Regards, Customer Support, Ultimate Tuning and Performance הוא מחרטט? אה וכמובן לינק למוצר: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310317915475&ssPageName=ADME:X:RTQ:MOTORS:1123
  3. אני רוצה להזמין לג'אז שלי ספוילר וחצאיות, הם באים בצבע שחור מוכן לצביעה, רציתי לדעת כמה צביעה על הדברים האלו יכולה לעלות? מדובר על חצאיות צד, ספוילר (כנף) אחורי ואולי גם ספוילר תחתון קדמי ואחורי (במידה ויהיה לי כסף לשלם על שני אלו, שכן יש רק מוגן, ואני לא בטוח שהם מתאימים לג'אז 08(צורה ישנה) הצבע הוא "אפור פנינה" והוא לא מטאלי או משהו יקר, צבע רגיל. ומישהו יודע כמה עולה התקנה של דבר כזה? רשום שמומלץ שיעשה ע"י מקצוען (אבל נשמע כמו עבודה של 5 דקות) למי שרוצה לראות מה בדיוק חשבתי להזמין אז הנא: ספוילר עליון אחורי: http://cgi.ebay.com/ebaymotors/HONDA-06-08-FIT-JDM-JAZZ-GD1-AX-REAR-WING-ROOF-SPOILER-_W0QQcmdZViewItemQQfitsZMakeQ3aHondaQ7cModelQ3aFitQQhashZitem45fa5e5a80QQitemZ300553230976QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories חצאיות(כי כל השאר עולות 300 לא כולל משלוח, קארבון..) http://cgi.ebay.com/ebaymotors/07-08-HONDA-FIT-PU-POLY-URETHANE-SIDE-SKIRT-SPOILER-JDM-_W0QQcmdZViewItemQQhashZitem25632f67e3QQitemZ160577841123QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories וספוילר אחורי וקדמי תחתון של מוגן: http://cgi.ebay.com/ebaymotors/09-10-Honda-Fit-Mugen-Rear-Under-Spoiler-MIlano-Red-_W0QQcmdZViewItemQQhashZitem3a5f907d61QQitemZ250711407969QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories http://cgi.ebay.com/ebaymotors/09-10-Honda-Fit-Mugen-Front-Under-Spoiler-Taffeta-White-_W0QQcmdZViewItemQQhashZitem3a5f90478bQQitemZ250711394187QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories המוכר אמר שזה יתאים לג'אז 08 צורה ישנה.. אבל לך תדע..
  4. ו5 דלתות זה לא סדאן (?)
  5. http://www.carsforum.co.il/vb/showthread.php?t=146267
  6. פתחתי אשכול דומה לפני יומיים, אני גם בן 17, ותחשוב שמעבר לכסף שתשקיע באוטו, אתה צריך לעשות גם ישור קו, ביטוח חובה ולפחות צד ג', טסט ומוסך פה ושם. אם להורים שלך יש מכונית, תשקול לעשות עליה ביטוח וזהו, יצא יותר זול.
  7. אני חושב שהכרית קצת יותר רכה מהדשבורד.. אבל זה אני
  8. matanff
    LADA GRANTA מה דעתכם?
    פוטין הסביר שהסיבה להתנעה מהפעם החמישית היא משום שהוא ניסה להתניע אותה "old style" ז"א, התנעה יחד עם לחיצה על דוושת הדלק.
  9. matanff
    שכחת לציין שברוסיה ההונדות מאוד יקרות (יחסית למכוניות אחרות) וזה לא מפתיע שהג'אז עולה הרבה יותר. הלאדה אכן זולה, ובמיוחד בגלל שהיא מיוצרת שם.
  10. זהו שאני חיפשתי את הפתרון הכלכלי ולא מה שטוב לי, כי אבא שלי משלם את רוב הכסף. ההורים שלי גם ככה בקושי נוגעים ברכב. הוא כבר 37K~ ב3 שנים..
  11. אני מאוד אוהב וחושק לנהוג ברכב של ההורים שלי, הסיבה היחידה שאני רוצה רכב משלי, כי טוב, בעצם אתה מבין, רכב שלי לא? שכחתי קצת מעניין הטיפולים והתחזוקה.. אני חושב שבאמת אבטח את עצמי על הרכב של ההורים. תודה רבה על העצה.
  12. הכל בגלל שהחוקים בארץ על הפנים, החוק של עקיפה מימין לא קיים במדינות ארה"ב ורוסיה לדוגמא, החוק בארץ אומר שגם אם מישהו נוסע 5 קמ"ש בנתיב השמאלי בכביש של 110 אתה לא עוקף אותו מימין, היכן ההגיון?
  13. בקרוב אני הולך לקבל את הרשיון שלי ומולי (מול אבא שלי יותר נכון) עומדות שני אפשרויות. אפשרות מספר 1: ברשותנו הונדה ג'אז 2008 LS אוטומת, המבוטחים עליה הם שני ההורים שלי (50+ עם מעל ל7 שנות רשיון לכל אחד, בקיצור הביטוח הכי זול שאפשר, בלי תאונות וכדומה) אבא שלי כמובן יעשה לי מקיף וחובה במידה ואנהג עליה, וזו הייתה התוכנית עד לא מזמן, ביררנו אצל סוכן הביטוח שלנו, וביטוח חובה + מקיף בשבילי יעלה ואני מצטט את סוכן הביטוח "1100 ל4 חודשים חובה + מקיף בערך אותו דבר" ז"א, שלשנה, הביטוח יעלה כתוספת של 6K! מחיר של פיאט פונטו! וכאן בדיוק הצעתי לאבא שלי את אפשרות מספר 2, פיאט פונטו ידנית כמובן משנות ה90 (רכב שהיה בבעלותו של אבי מ96 עד 02) עם 75 אולי 90 כ"ס, ובנוסף ביטוח, השאלה בקצרה : האם שווה פיאט פונטו באמת? מבחינה כספית, ההונדה חסכונית בטירוף, הביטוח שלה הוא בשמים! השאלה היחידה שלי היא בעצם כמה יעלה לנהג בן 17 ביטוח על פונטו או כל רכב דומה אחר? המטרה היא לחסוך כמה שיותר כסף, גם אם זה בטווח הרחוק. אני מצטער על החפירה, ותודה מראש לכל מי שעוזר. נעלו לי את האשכול הקודם כי כנראה לא כתבתי מה השימושים שלי.. הרכב המבוקש צריך להיות בעל צריכת דלק נמוכה ככל האפשר, ביטוח זול, והנסיעות יהיו בעיקר בעיר. אני מצטער אם שכחתי משהו, בבקשה אל תנעלו ישר תגידו לי מה להוסיף כי אני לא רואה עוד משהו שצריך להוסיף. השאלה העיקרית שלי האם כדאי לעשות ביטוח על האוטו של ההורים או לקנות אחד חדש.
  14. מבחינת אפקטים, זה משהו ששווה ללכת לקולנוע בשבילו או לראות בבית בHD על 40 אינץ' יספיק?
  15. איך זה הגיוני? הרי שבטורים גבוהים יותר, צריכת הדלק עולה בהתאם.
  16. אני ועוד כמה חברים נוסעים ליס פלנט חיפה ביום ראשון לראות, שמח לשמוע שנהנת.. הוא קיבל 7.8 בIMDB שיחסית לסרט כזה שאין לו ממש משמעות עמוקה זה ציון גבוהה.
  17. אצלנו באוטו יש אפשרות של ספורט בידית הילוכים, מה שזה בעצם עושה לפי מה שהבנתי, זה למשוך יותר את ההילוכים, וכמובן עליה בצריכת הדלק.
  18. ג'אז 2008 המודל הלפני אחרון אוטומת
  19. האם הוא קיים ברכב עם תיבת הילוכים רציפה CVT? כי לא מצאתי שם שום כפתור
  20. matanff
    דייהטסו YRV
    הרכב היה בשירות המשפחה שלנו 6 שנים, עברו בערך 100K הרכב היה אמין, נמכר אפילו עם אותו מצבר שנקנה (קנינו חדש מהחברה) הנסיעה בו בהשוואה למיני החדשות קצת קשיחה, מרגישים את הכביש יותר מדי.. צריכת הדלק בסדר גמור(נמוכה עד מאוד) הרכב לא ראה הרבה מוסך אצלנו, רק כמה בעיות ברדיו. סה"כ היינו מאוד מרוצים, והחלפנו אותו בגלל שרצינו להשתדרג וגם אחרי תאונה שהוא עבר.
  21. אה בעצם אם להורים שלי כבר יש ביטוח אני חוסך קצת?
  22. במידה ואני נהג חדש ואני רוצה לדעת כמה אני צריך להוסיף בשביל ביטוח חובה + מקיף על הרכב ששני ההורים שלי כבר מבוטחים עליו, קיים אתר שאני יכול לבדוק שם? הנציגים של חברות הביטוח לא סגורים על עצמם וחופרים יותר מדי.
  23. להתחיל לחשוש מקרינה במכוניות יפניות? קודם כל, רוב המכוניות היפניות בארץ לא מיוצרות ביפן למיטב ידעתי, דבר שני, אני לא חושב שיביאו לכאן מכונית שמלאה בקרינה וימכרו אותה ללקוח, עדיף להם לרכוש בעצמם מד גייגר מאשר להסתכן בתביעה.
  24. http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=NOS+SYSTEM%3C&_sacat=See-All-Categories
  25. בספק אם אבא שלי עובר את ה3
