LANZAR OPTI 1400D
נתונים :
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Remote Bass Control
Soft Turn On/Off
500 Watts RMS Power into 4 Ohms
800 Watts RMS Power into 2 Ohms
1000 Watts RMS Power into 1.3 Ohms
1300 Watts Max Power into 1.3 Ohms
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to +18dB
Phase Shift Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 4
Dimensions: 10.08'' (W) x 2.12'' (H) x 14.96'' (L)
המגבר השני..
SOLID AUDIO F15D
נתונים:
1500W x 1 @ 1 Ohm RMS
1150W x 1 @ 2 Ohm RMS
800W x 1 @ 4 Ohm RMS
Double sided through hole epoxy PCB
Gold plated brass set screw terminals
24dB / Octave variable
HP/LP crossover (30Hz - 500Hz)
Variable 0 to 18dB
Bass boost at 45Hz
Variable phase shift control (0° to 180°)
4-way protection and LED
Thermal/over current/speaker short/speaker DC
Daisy Chain through output RCA
Bass remote control
1 Ohm stable circuits
Damping factor >400 (THD 0.05%)
Dimensions (LxWxH): 17.32" x 9.88" x 2.01"
ההבדלים בעוצמות לא חשובים לי השאלה שלי איזה מגבר עדיף ?
המחיר לא חשוב כרגע אני שואל רק על שני המגברים האלו
תודה לעוזרים..
