אז ככה יש לי מערכת רמקולים של פוקל k2 100 קומפוננט השאלה שלי היא איזה מגבר יהיה טוב/איכותי יותר בשבילם?
1 boss c6500
2 hertz he4
שולח נתונים:
רמקולים specs:
component speaker system includes two 4" woofers, 2 tweeters, 2 external crossovers, and 2 woofer grilles
K2 Kevlar sandwich woofer cone
Tuned Mass Damper (TMD®) rubber surround
13/16" aramid fiber "M"-shaped inverted-dome tweeter
2-way external crossover with 3 tweeter level settings
4-ohm impedance
power range: handles up to 60 watts RMS (120 watts peak power)
frequency response: 110-22,000 Hz
sensitivity: 90 dB at 2.83 V
woofer mounting depth: 1-9/16"
מגבר בוס נתונים
boss spec:
Boss Chaos Series C650 Car Amplifier 4 Channel 1000 Watts
SKU: C650
RMS Power @ 4 Ohms: 100W x 4
THD at 4-Ohm RMS Power: 0.05 %
Bridged RMS Power @ 4 Ohms: 250W x 2
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 102 dB
MOSFET Power Supply
Variable Low-Pass Crossovers
Fixed 150Hz High-Pass Crossovers
Variable Bass Boosts
Line- and Speaker-Level Inputs
Dimensions: 11 3/16"W x 2 11/16"H x 15 7/16"L
hertz he4 spec:
מגבר הרטז נתונים
High pass filter: Variable from 40Hz to 400Hz measured at 12 dB / Octave
Low pass filter: Variable from 40Hz to 400Hz measured at 12 dB / Octave
Amplified channels: 4
Power output:
- 70W per channel into 4 ohms and THD 1%
- 100W per channel into 2 ohms and THD 1%
Bridge mode: Yes
Power: 200W into 4 ohms
Amplifier class: Class AB
Frequency response: 7 - 45kHz at +-3dB
Signal to noise ratio: 104 dB
Input impedance: Unbalanced: 15 kohms
Damping factor: Over 150 at frequencies from 100Hz to0.1kHz at 4ohms
Connectivity Inputs: Unbalanced (RCA): 4
Speaker connector type: Binding post terminals
