ברצוני לרכוש מגבר שיפעיל סט FOCAL K2P UP
עם דאבל וופר על המגבר הנ"ל
מבקש חוות דעת מקצועית בבקשה
כרגע הסט מתנגן על גיי בי אל העממי ואת התוצאות אתם כבר בטח מתארים.
מפרט טכני:
Cont. power rating RMS/Max. power at 4 Ohms RMS/12 V: 4 x 60/85 Watt
Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V: 4 x 85/160 Watt
Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V: 4 x 153/300 Watt
Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V bridged: 2 x 270/450 Watt
Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V bridged: 2 x 395/650 Watt
Total harmonic distortion:
Signal to noise ratio: > 100 dB
Damping factor: > 450
Frequeny range: 20 Hz -20 kHz
TIM distortion:
Input sensitivity: 500 mV - 8 V
Fuse: 3 x 25 A
Input impedance: 10 kOhm
Bassboost adjustable channel C und D: 0 - 9 dB
Dimensions (HxWxD) mm: 35 x 240 x 432
Weight net: 4,7 kg
Driver with class A technology
Outputstage with 24 MosFet transistors
RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
NFI (noisefree input) for distortion-free listening
Intelligent active crossover
Bass Boost Control 0-9 dB, adjustable center frequencies 30-120 Hz
Mono/Bridged/ Stereo switch
8.0 volt input for connection to any signal source
ADC - Anti Distortion Choke to eliminate distortions
Intelligent temperature and power controlled switching power supply
Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
CPS - Color Protection System
SMD - Surface Mounting Devices for constant assembling quality
Double-sided, extra strong (2x 110u) and copper plated pc-board for best power and signal transmission and protection against vibrations
24-karat gold-plated solid connectors suitable for 25 m²/ gauge 4 cables
Temperature-optimised heatsink for highest efficiency
1% accurate components for perfect audiophile sound quality and maximum power
Smoked-grey plexi cover with both side printing
