אני הזמנתי 3 פדים מEBAY
http://www.ebay.com/itm/222287646487?_trksid=p2060353.m2749.l2649&var=521124370921&ssPageName=STRK%3AMEBIDX%3AIT
צריך עזרה בזיהוי הצבעים/ של הפדים?? לפי הבנתי שחור - ווקס / גימור, כתום - פוליש גס, כחול פוליש עדין
About the Orange Medium-Heavy Pad
The Orange Hex-Logic Medium-Heavy Cutting Pad is a firm, high density foam pad that is ideal for scratch and defect removal. This pad offers the correction of a typical compounding pad while at the same time allowing the polishing ability of a light cut foam pad. When used with heavier compounds, it will remove moderate swirls and scratches with little or no haze. It is an all around pad that will work on most light to moderate imperfections.
About the Black Finishing Pad
The Black Hex-Logic Finishing Pad is a super fine finishing pad that has no cut so it can apply thin, even coats of waxes, sealants and glazes. The super fine composition of the finishing pad is firm enough to withstand added pressure during final finishing to deliver a perfect result every time.
About the Blue Light Polishing/Finishing Pad
The Blue Light Polishing/Finishing Pad delivers a super fine finish for use with ultra fine polishes, glazes and light surface cleaners.
