Or Elgavi
כל מה שפורסם על ידי Or Elgavi
אפשר לינק? איך זה? http://redirect.viglink.com/?format=go&jsonp=vglnk_148554301040314&key=6b34d993f2090e8bb6f50e92db592939&libId=iyg5u4n401002nxr000DA7txrh6nq&loc=http%3A%2F%2Fwww.carsforum.co.il%2Fvb%2Fshowthread.php%3F622167-%25D7%2590%25D7%2599%25D7%25A0%25D7%2598%25D7%25A8%25D7%25A0%25D7%2598-%25D7%2590%25D7%259C%25D7%2597%25D7%2595%25D7%2598%25D7%2599-%25D7%2591%25D7%25A8%25D7%259B%25D7%2591&v=1&out=https%3A%2F%2Fwww.aliexpress.com%2Fitem%2FUnlocked-Huawei-CarFi-E8377-Hilink-LTE-Hotspot-4G-LTE-Cat5-12V-Car-Wifi-Router-PK-huawei%2F32590771828.html%3Fspm%3D2114.01020208.3.9.WJZSeM%26ws_ab_test%3Dsearchweb0_0%2Csearchweb201602_2_10065_10068_10000032_119_10000025_10000029_430_10000028_10060_10062_10056_10055_10000062_10054_301_10059_10099_10000022_10000012_10103_10000015_10102_10096_10000018_10000019_10000056_10000059_10052_10053_10107_10050_10106_10051_9985_10000053_10000007_10000050_10084_10083_10118_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10037_10032_10000041_10000044_10078_10079_10077_10000038_429_10073_10000035_10121%2Csearchweb201603_10%2Cafswitch_3%2Csingle_sort_3_total_weight_score_desc%26btsid%3D29f7b790-ede1-49d8-9c21-100354bf4f0e&ref=http%3A%2F%2Fwww.carsforum.co.il%2Fvb%2Fforumdisplay.php%3F15-%25D7%25A4%25D7%2595%25D7%25A8%25D7%2595%25D7%259D-%25D7%2590%25D7%2595%25D7%2593%25D7%2599%25D7%2595-%25D7%2595%25D7%259E%25D7%2595%25D7%259C%25D7%2598%25D7%2599%25D7%259E%25D7%2593%25D7%2599%25D7%2594-%25D7%259C%25D7%25A8%25D7%259B%25D7%2591&title=%D7%90%D7%99%D7%A0%D7%98%D7%A8%D7%A0%D7%98%20%D7%90%D7%9C%D7%97%D7%95%D7%98%D7%99&txt=https%3A%2F%2Fwww.aliexpress.com%2Fitem%2FUnlo...1-100354bf4f0e&loAsUuid=iyg5u63r-18c92d0f-a849-4872-9184-c5f4de00b1d7
במולטימדיה שמגיעה עם הספורטאז אין איך המוצר הזה? https://www.aliexpress.com/item/Unlocked-Huawei-CarFi-E8377-Hilink-LTE-Hotspot-4G-LTE-Cat5-12V-Car-Wifi-Router-PK-huawei/32590771828.html?spm=2114.01020208.3.9.WJZSeM&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000032_119_10000025_10000029_430_10000028_10060_10062_10056_10055_10000062_10054_301_10059_10099_10000022_10000012_10103_10000015_10102_10096_10000018_10000019_10000056_10000059_10052_10053_10107_10050_10106_10051_9985_10000053_10000007_10000050_10084_10083_10118_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10037_10032_10000041_10000044_10078_10079_10077_10000038_429_10073_10000035_10121,searchweb201603_10,afswitch_3,single_sort_3_total_weight_score_desc&btsid=29f7b790-ede1-49d8-9c21-100354bf4f0e
שלום לכולם, אחרי חודש התנסות בלתת למערכת בספורטאז' החדשה נקודת גישה מהפלאפון, נשבר לי. יש לי סים של חברת אורנג' (מקבל מהחברה שאני עובד בה) אני מחפש את המכשיר הנכון לרכב בשביל לתת אינטרנט אלחוטי באופן קבוע אשמח להכוונה/הדרכה/לינק אני לא מבין בתדרים או באופן כללי באינטרנט אלחוטי ברכב, אז ממש אשמח להכוונה. תודה
מדריך מולטימדיה קיה ספורטאז
Or Elgavi פרסם הודעה בנושא של Or Elgavi בתוך פורום אודיו ומולטימדיה לרכב
בן אדם רושם מדריך מפורט לפריצת מערכת המולטימדיה ברכב הנפוץ ביותר היום, מה שאנשים לא מצאו וחיפשו הרבה זמן. כבר 100 צפיות, אפילו לא תגובה אחת? :-(:-(:-(:-(:-( -
היי חברים, אחרי ישיבה של 3 שעות בקיה ספורטאז החדשה סוף כל סוף הצלחתי לשבור את המולטימדיה הזו. לפני הכל: 1. השימוש על אחריותך בלבד 2. אני לא איש מקצוע והכל נעשה פרי סטייל עד שמצאתי את הדרך. המטרה: התקנת אפליקציות ושימוש חופשי במערכת המולטימדיה שבאה עם הקיה ספורטאז החדשה. שלבים: 1. הגדרות>גיבוי> הכנסה של חשבון גוגל כלשהו שברשותכם. מכניסים מייל וסיסמה לוחצים על הבא ונותנים לו לסיים לחשוב 2. נכנסים במסך הראשי לספר הרכב, כשאתם בפנים יש בפינה הימנית העליונה 3 נקודות לוחצים עליהן ואז יש אפשרות לעשות SHARE לוחצים על SHARE ואז בוחרים דרך הGMAIL 3. נפתח לכם מסך עם שליחת מייל חדש בג'ימייל, במסך עצמו יש לחצן אחורה כזה, ברגע שלוחצים על הלחצן הזה ולא על לחצן אחורה של המערכת הוא פשוט סוגר את חלון שליחת המייל החדש ואתם כרגע בתוך הג'ימייל שלכם. 4. שולחים לעצמכם לינק לגוגל פותחים את המייל לוחצים על הלינק ונכנסים לגוגל דרך הדפדפן. 5. בגוגל עושים חיפוש של 'חנות PLAY' שזו בעצם חנות האפליקציות של האנדרואיד. נכנסים אליה ועכשיו אתם בתוך החנות, לכאורה יכולים להתקין איזה אפליקציה שתרצו אבל לא כך הדבר כי גם אם תתקינו המערכת חסומה ולא תראה לכם את האייקונים של האפליקציות שהורדתם במסך הבית. 6. כשאתם בתוך החנות מחפשים אפליקציה של גוגל שנקראת מפעיל אפליקציות מתקינים אותה. 7. לאחר סיום התקנה חוזרים למסך הבית הרגיל שאתם מכירים, נכנסים להגדרות ושם מחפשים שורה שנקראת תצוגת מסך הבית. לוחצים על זה. במידה ועשיתם את כל השלבים קודם לכן נכון אתם תיראו שם 3 שורות. הסבר כללי על השורות הללו: אחת זה התצוגה הרגילה שאתם מכירים עם קבלת הרכב. תצוגה שניה זו תצוגה של היצרן אין מה לעשות שם, תצוגה שלישית זה בעצם האפליקציה שהורדתם שנקראת מפעיל אפליקציות. בוחרים בה. 8. לא להבהל התצוגה השתנתה, אפשר תמיד לחזור למה שהיה כפי שכתוב בשלב 7. תתחדשו יש לכם את החנות של גוגל בין שאר האפליקציות המותקנות שם תוכלו להכנס אליה ישירות כעת ולהתקין איזו אפליקציה שתרצו וגם לראות אותה על גבי מסך הבית. תהנו.
היי לכולם, קניתי קיה ספורטאז חדשה שקיבלתי לפני שבוע וחצי. הפורום עזר לי לא מעט והחלטתי לשתף את החוויה גם בגלל החוויה עצמה. שורה תחתונה. ניראה שקיה באופן כללי עדין לא הפנימה את היותה מותג רכבים עם רמת מכירות הגבוהה בארץ. נתחיל בקבלת הרכב, אין איזושהי חוויה או הרגשה טובה, אתה אחד מתוך עשרות אלפים גם בהרגשה לא רק באמת, הרכב עצמו היה מלוכלך במספר נקודות וגם היה נדרש לחזור לפוליש קצר כדי להוריד לכלוך קטנציק בצבע. ההסבר על הרכב היה מהיר ממצה ולעיתים חסר סבלנות, העיקר שאחתום על קבלת הרכב. כשהגעתי לבית גיליתי שאין ספר רכב בתא כפפות. כשהתקשרתי לבקש שישלחו לי או יכינו לי באחת הסוכניות העבירו אותי לכמה וכמה נציגים חסרי סבלנות. עד שהבטיחו לי שישלחו לי הביתה, טרם קיבלתי. לאחר מספר ימים הבנתי שהדלת לא מכוונת מעט והייתי צריך ללכת למוסך לכיוון שלה. לא ממש הפריעה לי העובדה שצריך ללכת לכוון זה קורה בכל מקום. כשהתקשרתי למוסך המרכזי וגם כשהייתי שם התחושה הייתה של רק תלך מפה, זה מסודר אין לך מה לדאוג העיקר תלך. הרכב עצמו אני דווקא נהנה ממנו הוא 1600 וסוחב בסדר גמור וומש נהנה גם ביחס לכל גיפון אחר שניסיתי. בכל מקרה קחו בחשבון, רכב משתלם אבל אמא ואבא חורגים!
ספורטאז' חדשה, דלתות קידמיות לא נסגרות טוב
Or Elgavi פרסם הודעה בנושא של Or Elgavi בתוך טכני, אחזקה וטיפולים
אתה מתכוון לחיבור של הטמבון לחלק שבא אחריו ברכב? כי אם כן כן אני שם לב לזה כל המעטפת של הרכב כאילו אין שם בקרת איכות טובה שבאמת שמה את כל החלקים על המילימטר הנכון. יתכן דבר כזה? -
איך אפשר לדעת אם באמת הדלת מקורית או שהוחלפה או האם הרכב ניזוק בהגעה לארץ או היה בתצוגה? יש דרך לדעת משהו כזה על הרכב? -
בוקר טוב קיבלתי את הספורטאז החדשה ביום שלישי האחרון, אתמול בערב להפתעתי הבחנתי שהדלת שליד הנהג כאשר היא סגורה היא לא יושב 'אפס' עם הדלת שלידה. כאילו היא לא נסגרת טוב, ההבדל הוא לא בולט לעין ורק אם מסתכלים ומעבירים את היד רואים את זה. השאלה שלי אם כדאי לקחת את זה למוסך המרכזי, או שעדיף להתעלם מזה. שוב ההבדל הוא לא משהו בולט לעין אבל כן מעצבן. ועוד שאלה האם מישהו נתקל בזה.
היי אני רוצה להרכיב את המוצר הזה בקיה ספורטאז החדשה. למישהו יש מושג איך מחברים את זה לחשמל? יש דרך להשיג לזה מדריך תודה המוצר המדובר: https://www.aliexpress.com/item/Excellent-stainless-steel-threshold-door-sills-scuff-plate-For-KIA-SPORTAGER-2010-with-LED-light-4/717273856.html?spm=2114.01010208.3.10.H1PQzp&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10059_10032_10099_10078_10079_10077_427_10103_10073_10102_10096_10052_10050_10051,searchweb201603_9,afswitch_5&btsid=4b3e902c-67fd-49ad-b730-9bd055e983f6
אוקי אני מנסה ומעדכן
שלום לכולם יונדאי אקסנט לא מניע לי, לא עושה גם קולות של ניסיון חלש להניע חיברתי כבלים, אין תגובה או שינוי. מה יכולה להיות עוד הבעיה? תודה
מצטרף לשאלה ובכלל, ניסיתי לחפש מידע על מערכת המולטימדיה כאן ולא הצלחתי למצוא כיצד לפרוץ? האם עדיף להתקין דונגל באופן פרטי? כיצד משדרגים? האם מישהו יודע את קוד הנעילה? תודה לעוזרים
כשהלכתי במטרה לרכוש את הנירו או הספורטאז החדשה, מתוך רצון להתחדש בג'יפון הנירו ירדה לי מהעין תוך דקה וחצי, ישר במבט ראשון רואים את ההבדלים בגודל, הנירו ניראה כמו האצ'באג מנופח ואילו הספורטאז ניראת כגדולה והמרווחת מבין הג'יפונים. בתור אחד שנוסע 15 קמ ביום לעבודה ומוציא כ500 שקל דלק בחודש, צריכת הדלק לא הייתה שיקול מהותי, אך בהחלט מפתה לחסוך כחצי מעלות הדלק החודשית. יחד עם זאת המטרה לשמה החלפתי לגי'פון (ספורטאז) היא לתת מרווח לנוסעים האחרים ברכב מאחורה ומקדימה כולל סל קל וכלב וכמו כן לשים בתא מטען עגלה עם אמבטיה, שקיות קניות, ושאר זבל'ה בלי שאצטרך לסדר כל דבר על המילימטר כדי שיכנס, והספורטאז בהחלט עושה את העבודה בתחום של המרווח. לכן אם מרווח ומראה של ג'יפון פחות הקטע שלך ואתה נוסע הרבה אז נירו, אחרת ספורטאז
הלכתי לראות על מה מדברים לא שאני מבין גדול, סתם הלכתי להתרשם מהבופה שהציעו ליד המכונית החדשה. לדעתי בלבד, פיג'ו פיספסו ובגדול במספר לא מבוטל של דברים: 1. בראש ובראשונה, תיבת הילוכים והפרדה בין נהג לזה שלידו גבוהים מאוד מה שמחייב את רגל ימין להיות ישרה וזה מאוד לא נוח. 2. תא הנהג גם בגלל מה שרשמתי מעלה וגם באופן כללי קטן מאוד, הרגשתי ממש בתוך תא של פורמולה 1. 3. באיזשהו מקום כל העיצוב המוגזם הזה נותן תחושה של רכב ל"ילד מתלהב" ולא לרכב משפחה/מנהלים. 4. מושב הנהג מחבק את הנהג, מדמה רכב ספורט, יש שיאהבו יש שלא, אני לא אוהב יותר מרגיש לי צפוף מאשר מגניב 5. הריפודים!!!! מ ז ע ז ע בדגם האקטיב הבסיסי, ממש ניראה כאילו נלקחו מלפני כמה שנים טובות עם גימור רע 6. כל מה "ששכחו" לעצב ברכב נשאר הרחק מאחור, כך שיש פערים גדולים בעיצוב, מצד אחד כל הדשבורד ניראה כמו חללית, מצד שני לחצני החלונות בדלת של תא הנהג ניראים של פיאט פונטו 98. 7. ישיבה נמוכה יחסית לג'יפים אחרים. 8. כיסאות אחורים מתקפלים אבל ממש לא לזווית שהופכת את התא להרבה יותר גדול כמו בספורטאז למשל. שורה תחתונה, ההתלהבות הראשונית תניב לדעתי פרץ של רכישות אבל מהר מאוד יבינו שיש כאן לא מעט פיספוסים שלא ניתן הבליג עליהם
תשובות יפות, מי שלא שאלתי לא ענה ככה. תודה
שלום לכולם אני ממש מתלבט אם להחליף את הספורטאז שהזמנתי ל3008 החדשה. סליחה על השאלה של ילד אידיוט. למה מנוע 1.6 ליטר של דיזל עולה פחות מהבנזין למה הוא מספק כוחות סוס כל כך נמוכים והאם זה מספיק לדעתכם? ולמה לא לקחת אותו כשגם המחיר שלו זול יותר וגם צריכת הדלק שלו נמוכה יותר
חייב להתייעץ אתכם הזמנתי ספורטאז חדשה שמתי 2000 דמי קדימה, אני יכול לבטל עוד. השאלה אם כדאי ללכת על הפיגו בלי לתת לה להתגלגל כאן בשוק קצת
אשמח לשמוע כל פרט שיש לכם על ה3008 החדשה. מתי מגיע? מה אתם חושבים? אילו גירסאות? סביבות מחיר? וכו'
הבדלים משמעותיים בין קיה ספורטאז 1.6 ל 2.0
Or Elgavi פרסם הודעה בנושא של shaycha בתוך ייעוץ ברכישת רכב
התכוונתי שזה מצחיק שזה מה שאומרים עליו, הוא "עגלה" ולמרות זאת נרכש ללא הפסקה -
בדקתי את נושא ההנחה מדובר על 1500 שקל ולא 5% כי זה עד 1500 שקל בכל מקרה מדובר על הבדל של 12.5 אלף שקל. ואני לא יודע איזה שנה אתה מקבל, כי את הספורטאז אתה יכול לקנות במחיר עכשיו ולקבל 2017. מבחינת איבזור אני לא יודע מה מקבלים בליסינג וגם אולי כדאי שתפתח נושא ותשאל כי יש הבדלים ברכישה מליסינג, כל מיני טיפים שנתנו כאן -
מקבלים מהיבואן חיישני רוורס מצלמת רוורס מולטימדיה מגלשים קידמי אחורי ואיתורו. כמה זה יוצא לך מחיר סופי אחרי ההנחה? זה מצחיק שהרכב הנמכר ביותר בארץ הוא עגלה. אנשים מתעלמים מהצרכים של הנוסע ויוצאים בהצהרות. -
מולטימדיה/נקודת גישה ספורטאז החדשה
אשמח לדעת עוד בעלי אייפון איך הם מחברים את המולטימדיה לאינטרנט -
איפה הלכתם עם הדיון. מה שאלתי ומה הקשר לברזלים במדינות עולם שלישי ולטלוויזיות. שורה תחתונה מישהו יודע איך מקבלים הנחות בקיה?
לא קיבלתי את הרכב, רק רכשתי. אני פשוט חושש מהחיבור הזה של הפלאפון בכל כניסה לרכב, כל דבר שהוא לא אוטומטי זה מטריד ובסוף לא בשימוש. הדונגל הזה מאחורה נשמע כמו הפתרון הנוח השאלה כמה עולה בקניה ובכל חודש
